HP Z238 Microtower Workstation Specifications
Product image
Figure : HP Z238 Microtower Workstation
Processors
Intel Xeon E3-1240 v6
3.7 GHz
Up to 4.1 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
With Intel HD Graphics P630
72 W
Supports DDR4 memory up to 2400 MT/s data rate
Intel Xeon E3-1240 v5
3.5 GHz
Up to 3.9 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
80 W
Supports DDR4 memory up to 2133 MT/s data rate
Intel Xeon E3-1230 v6
3.5 GHz
8 MB cache, 4 cores
72 W
Intel Xeon E3-1230 v5
3.4 GHz
Up to 3.8 GHz with Intel Turbo Boost Technology
8 MB L3 cache, 4 cores
80 W
Intel Xeon E3-1255 v6
3.3 GHz
Up to 3.7 GHz with Intel Turbo Boost Technology
73 W
Intel Xeon E3-1255 v5
3.3 GHz
80 W
Intel Xeon E3-1205 v6
3.0 GHz
65 W
Intel Core i7-7700
3.6 GHz
Up to 4.2 GHz with Intel Turbo Boost Technology
With Intel HD Graphics 630
65 W
Intel Core i7-6700
3.4 GHz
Up to 4.0 GHz with Intel Turbo Boost Technology
With Intel HD Graphics 530
65 W
Intel Core i5-7500
3.4 GHz
6 MB L3 cache, 4 cores
65 W
Intel Core i5-6600
3.3 GHz
Up to 3.9 GHz with Intel Turbo Boost Technology¥
65 W
Intel Core i3-7100
3.3 GHz
3 MB L3 cache, 2 cores
51 W
Intel Core i3-6100
3.7 GHz
51 W
Intel Pentium G4560
3.5 GHz
With Intel HD Graphics 610
54 W
Intel Pentium G4400
3.3 GHz
With Intel HD Graphics 510
54 W
Intel Core i5/Core i7 and Xeon with vPro technology capable (optional)
Intel Virtualization Technology (Intel VT)
Intel Trusted Execution Technology (Intel TXT)
Intel Active Management Technology (iAMT)
Intel C236
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Turbo Boost is based on maximum GHz for a single core.
Intel HD Graphics P530 and P630 supports workstation-specific graphics drivers for improved compatibility and performance on select professional applications, compared to Intel HD Graphics 530 and 630.
Graphics
Feature
Integrated Intel Graphics Media Accelerator (GMA) HD graphics
High-definition (HD) content is required to view high definition images.
Professional 2D
NVIDIA NVS 310 512 MB Graphics (can be mixed with one NVS 510)
NVIDIA NVS 315 1 GB Graphics
NVIDIA NVS 510 2 GB Graphics (can be mixed with NVS 310)
Entry 3D
AMD FirePro W2100 2 GB Graphics
NVIDIA Quadro K420 2 GB Graphics
NVIDIA Quadro K620 2 GB Graphics
Mid-range 3D
NVIDIA Quadro K1200 4 GB Graphics
Intermixing integrated Intel HD graphics and discrete graphics cards in order to drive more than three displays can be enabled using the computer (F10) Setup Utility. However, it is recommended using only discrete graphics when four or more displays are to be supported.
Displays
Feature
Monitors/displays
HP Z Display Z30i 30-inch IPS LED Backlit Monitor
HP Z Display Z24i 24-inch IPS LED Backlit Monitor
HP Z Display Z23i 23-inch IPS LED Backlit Monitor
HP Z Display Z22i 21.5-inch IPS LED Backlit Monitor
HP DreamColor Z24x Professional Display
HP DreamColor Z27x Professional Display
Supported by all operating systems available from HP.
Storage and drives
Feature
SATA 6.35 cm (2.5 in) hard drives
500 GB, 7.2 K rpm, 6.35 cm (2.5 in) SATA
1 TB, 7.2 K rpm, 6.35 cm (2.5 in) SATA
2 TB, 7.2 K rpm, 6.35 cm (2.5 in) SATA
3 TB, 7.2 K rpm, 6.35 cm (2.5 in) SATA
4 TB, 7.2 K rpm, 6.35 cm (2.5 in) Enterprise Class SATA
HP SATA Solid state drive (SSD)
HP 256 GB SATA 6 Gb/s SSD
HP PCIe SSDs
HP Z Turbo Drive G2 256 GB SSD
HP Z Turbo Drive G2 512 GB SSD
Hard drive controllers
Integrated SATA controller (Z230)
RAID 0,1 supported
(4) 6 Gb/s ports
Integrated RAID on motherboard for SATA drives
RAID 0 configuration – Striped array
RAID 1 configuration – Mirrored array
Integrated RAID for PCIe SSD
RAID 0 data configuration
RAID 1 data configuration
Windows OS only.
Supported only with two drives of identical type and capacity.
Optical and removable storage
HP 9.5 mm Slim DVD-ROM drive
HP 9.5 mm Slim SuperMulti drive
HP 15-in-1 media card reader
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
SATA hardware RAID is not supported on Linux systems.
Memory
Specification
Slots
(4) DIMM
Supporting up to 64 GB ECC/non-ECC, DDR4 2133 MT/s
Two channels of DDR3 and DDR4 memory are supported. To realize full performance at least one DIMM must be inserted into each channel. ECC and non-ECC memory DIMMs must not be mixed on the same system.
Only unbuffered DDR3 DIMMs are supported.
DDR4-2400 ECC Unbuffered DIMMs - CTO
4 GB DDR4-2400 ECC (4 GB x 1) RAM
8 GB DDR4-2400 ECC (4 GB x 2) RAM
8 GB DDR4-2400 ECC (8 GB x 1) RAM
16 GB DDR4-2400 ECC (8 GB x 2) RAM
32 GB DDR4-2400 ECC (8 GB x 4) RAM
32 GB DDR4-2400 ECC (16 GB x 2) RAM
64 GB DDR4-2400 ECC (16 GB x 4) RAM
DDR4-2400 non-ECC Unbuffered DIMMs - CTO
4 GB DDR4-2400 non-ECC (4 GB x 1) RAM
8 GB DDR4-2400 non-ECC (4 GB x 2) RAM
16 GB DDR4-2400 non-ECC (8 GB x 2) RAM
32 GB DDR4-2400 non-ECC (8 GB x 4) RAM
64 GB DDR4-2400 non-ECC (16 GB x 4) RAM
DDR4-2133 ECC Unbuffered DIMMs - CTO
HP 4 GB (4 GB x 1) DDR4-2133 ECC RAM
HP 8 GB (4 GB x 2) DDR4-2133 ECC RAM
HP 8 GB (8 GB x 1) DDR4-2133 ECC RAM
HP 16 GB (8 GB x 2) DDR4-2133 ECC RAM
HP 32 GB (8 GB x 4) DDR4-2133 ECC RAM
HP 64 GB (16 GB x 4) DDR4-2133 ECC RAM
DDR4-2133 non-ECC Unbuffered DIMMs CTO
HP 4 GB (4 GB x 1) DDR4-2133 non-ECC RAM
HP 8 GB (4 GB x 2) DDR4-2133 non-ECC RAM
HP 16 GB (8 GB x 2) DDR4-2133 non-ECC RAM
HP 32 GB (8 GB x 4) DDR4-2133 non-ECC RAM
HP 64 GB (16 GB x 4) DDR4-2133 non-ECC RAM
DDR4-2400 ECC Unbuffered DIMMs - AMO
HP 4 GB (4 GB x 1) DDR4-2400 ECC Unbuffered RAM
HP 8 GB (8 GB x 1) DDR4-2400 ECC Unbuffered RAM
HP 16 GB (16 GB x 1) DDR4-2400 ECC Unbuffered RAM
DDR4-2400 non-ECC Unbuffered DIMMs - AMO
HP 8 GB (8 GB x 1) DDR4-2400 non-ECC Unbuffered RAM
PROMO 4 GB (4 GB x 1) DDR4-2400 non-ECC Unbuffered RAM
DDR4-2133 ECC Unbuffered DIMMs - AMO
HP 16 GB (16 GB x 1) DDR4-2133 ECC RAM
DDR4-2133 non-ECC Unbuffered DIMMs - AMO
HP 8 GB (8 GB x 1) DDR4-2133 non-ECC RAM
HP 16 GB (16 GB x 1) DDR4-2133 non-ECC RAM
Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Due to the non-industry standard nature of some third-party memory modules, only HP branded memory is recommended to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Intel Xeon E3, Core i3 and Pentium processors support either ECC or non-ECC memory; Intel Core i5/i7 processors only support non-ECC memory.
Ports/slots/bays
Ports
Front
(2) USB 3.0
(2) USB 2.0
(1) Headphone
(1) Microphone
Internal
(1) USB 3.0
(3) USB 2.0
The USB ports are available as 2 separate 2 x 10-pin (3.0 x 1, 2.0 x 1) and 2 x 5-pin (2.0 x 2) header
Supports (1) HP Internal USB 2.0 port kit and (1) USB 3.0 media card reader
Rear
(3) DisplayPort (DP) 1.2 outputs from Intel HD graphics (available on specific processors only)
(6) USB 3.0 ports
(1) Serial port (standard)
(2) PS/2
(1) RJ-45 (LoM)
(1) Audio Line-in
(1) Audio Line-out
(1) PCIe Gen 3 x16 slot
If not used for a graphics card, only cards certified as After Market Options (AMO) for this platform are supported.
(1) PCIe Gen 3 x1 slot/x1 connector
(1) PCIe Gen 3 x4 slot/x16 connector
Expansion bays
(2) Internal 8.89 cm (3.5 in) bays
Digital media slots
SD media card reader (optional)
Audio/multimedia
Feature
Audio
Integrated
Realtek HD ALC221 Audio Codec
Input devices/adapters
Feature
Keyboard
HP USB 1000dpi Laser Mouse
HP USB Optical 3-Button Mouse
HP USB Optical Mouse
HP PS/2 Mouse
HP USB Business Slim Keyboard
HP PS/2 Business Slim Keyboard
Graphics cable adapters
HP DisplayPort to DVI-D adapter
HP DisplayPort To DVI-D adapter (2-pack)
HP DisplayPort To DVI-D adapter (4-pack)
HP DisplayPort to VGA adapter
HP DisplayPort to Dual Link DVI adapter
Other hardware
HP Power cord kit
HP Serial port adapter
Networking
Feature
Communications
Integrated Intel I219LM PCIe GbE Controller (Intel vPro with Intel AMT 11.0)
Intel Ethernet I210-T1 PCIe NIC
Power
Power supply
90 to 264 VAC at 47 to 63 Hz
280 W
85% Efficiency wide-ranging
Active Power Factor Correction (PFC)
Physical specifications
Dimensions (H x W x D)
355.6 x 165.1 x 358.14 mm (14.0 x 6.5 x 14.1 in)
Minimum
6.42 kg (14.15 lb)
Typical
6.99 kg (15.41 lb)
Maximum
7.90 kg (17.41 lb)
As configured with (2) 8.89 cm (3.5 in) Hard drive, (1) Optical drive, (2) DIMMs, and (1) NVIDIA Quadro K620 graphics card.
Exact weights depend upon configuration.
Software/security
Specification
BIOS
Standard BIOS 32-bit Service Directory Proposal v0.4
Digitally and cryptographically signed
Master Boot Record Protection
UEFI 2.4.0
ACPI version 4.0
HP Performance Advisor
Supports, and preinstalled with, Windows 7 and Windows 8 only. Also available as a free download from HP Performance Advisor website.
HP Remote Graphics Software (RGS) 7.1
PDF Complete (corporate edition)
HP PC Hardware Diagnostics UEFI (supported for Windows 10 Pro and 7 Pro)
HP Client Security Software
Integrated Trusted Platform Module (TPM) 1.2
Workstation ISV certifications
Go to the Workstation ISV Certifications webpage to see current certifications
Operating systems
Feature
Preinstalled
Windows 10 Pro 641
Windows 10 Home 64 High End1
Windows 10 Home 64 Chinese Market CPPP1
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro 64)2
HP Linux-ready
Supported
Windows 10 Enterprise 64
Windows 7 Enterprise 32 and 64
Windows 7 Professional 32
Red Hat Enterprise Linux Desktop 6, 7
SUSE Linux Enterprise Desktop 11 SP3, 12
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
2This system is preinstalled with Windows 7 Pro software and also comes with a license and media for Windows 10 Pro software. Only one version of the Windows software can be used at a time. Switching between versions requires uninstalling one version and installing the other version. Back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of data.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Environmental
Feature
Certifications
US ENERGY STAR (select configurations-Windows only)
US Federal Energy Management Program (FEMP)
China Energy Conservation Program
IT ECO declaration
EPEAT Gold registered where applicable (registration varies by country/region)
Low halogen
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-40° to 140°C (40° to 284°F)
Humidity
Operating
8% to 85%
Non-operating
8% to 90%
Altitude (unpressurized)
Operating
3,000 m (9,842.5 ft)
Non-operating
9,1000 m (29,855 ft)
