Samsung MFP SCX-4621 - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge. When a toner cartridge has reached the end of life, the printer will stop printing.
  • Shake the toner cartridge thoroughly, it will increase the initial print quality.
  • Illustrations on this user’s guide may differ from your printer depending on its options or models. Check your printer type.
  • To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover it with a piece of paper, if necessary.
  • Do not touch the green area of the toner cartridge. Use the handle on the cartridge to avoid touching this area.
  • Do not use sharp objects such as a knife or scissors to open the toner cartridge package. They might scratch the drum of the cartridge.
  • If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
Replacing the toner cartridge
Use these steps to replace the toner cartridge.
  1. Open the front cover.
    Figure : Open the front cover
  2. Remove the used toner cartridge from the printer.
    Figure : Remove the used toner cartridge
  3. Remove the new toner cartridge package from the box, and then distribute the toner by gently rocking the toner cartridge back and forth.
    Figure : Gently rock the new toner cartridge
  4. Unfold the handle on the toner cartridge (1) and remove the tape and protective shield (2, 3).
    Figure : prepare the new toner cartridge
  5. Grasp the toner cartridge by the handle and gently insert it into the printer.
  6. Close the front cover.
    Figure : Close the front cover
