HP Stream 11 Pro G4 EE Notebook PC - Specifications
Operating systems
Feature
Operating systems
Windows 10 Pro (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
Windows 10 S
Windows 10 S works exclusively with apps from the Windows Store. Some accessories and apps compatible with Windows 10 might not work, and performance varies. Certain default settings, features, and apps cannot be changed. Easily switch to Windows 10 Pro configuration (fee applies).
Windows 10 Pro 64 (recommended by HP)
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, and/or software to take full advantage of Windows functionality.
Processors
Feature
Intel Celeron N3350
1.1 GHz, up to 2.4 GHz
2 MB cache, 2 cores
Intel HD Graphics 500
Intel Celeron N3450
1.1 GHz, up to 2.2 GHz
2 MB cache, 2 cores
Integrated with procesor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors runs at lower speeds in battery optimization mode.
Graphics
Feature
Integrated
Intel HD Graphics 550
High-definition (HD) content is required to view high definition images.
Supports
HD Decode
DirectX 11
HDMI (cable not included)
Feature
Non-touch panel
29.46 cm (11.6 in) diagonal HD SVA eDP WLED anti-glare; 220 cd/m2; 45% sRGB (1366 x 768)
Touch panel
29.46 cm (11.6 in) diagonal HD UWVA WLED slim touch screen; 220 cd/m2; 50% sRGB (1366 x 768)
HDMI
Supports resolutions up to 1920 x 1080 external resolution at 60 Hz
HDMI cable not included.
Resolutions are dependent upon monitor capability, and resolution, and color depth settings.
Storage
Feature
Primary storage
eMMC
64 GB eMMC
128 GB eMMC
Maximum
128 GB
For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Feature
Standard
DDR3L-1600 SDRAM (transfer rates up to 1600 MT/s)
Dual channel support
Not customer accessible/not upgradeable
Configurations
4 GB (256 MB x 16 x 8 pcs)
Maximum
4 GB
Audio/multimedia
Feature
Audio
(2) Integrated stereo speakers
VGA camera
Indicator LED, USB 2.0
640 x 480 by 24 frames per second
Single digital microphone
Enable HP Noise Cancellation (must be enabled in Audio Control Center)
Keyboard/pointing device
Feature
Keyboard
Full size textured island-style keyboard
Pointing device
Clickpad with multi-touch gestures enabled
Taps enabled as default
Ports/connectors/slots
Feature
Ports and connectors
(1) HDMI 1.4b
(1) USB 2.0 port (left)
(1) USB-A 3.1 Gen 1 port (right)
(1) Headphone/microphone combo jack
(1) AC power connector
Slot
(1) Multi-format digital media reader
Supports SD/SDHC/SDXC.
Networking/communication
Feature
Wireless
Intel Dual band Wireless-AC 7265 802.11a/b/g/n/ac (2x2) Wi-Fi with Bluetooth 4.2 Combo (non-vPro)
Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Software/security
Feature
Buy Office
HP Jumpstart
HP Documentation
Retail Demo - Video Attract Loop Lite
Windows 10 Recovery Manager
Windows 10 Push Button Reset Recovery
HP Audio Switch
HP Support Assistant (requires Windows and Internet access)
HP Sure Connect
Bing search for Internet Explorer 11
HP ePrint Driver with JetAdvantage
Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP School pack
Security
Security lock mini slot (lock must be purchased separately)
Trusted Platform Module (TPM) 1.2/2.0
Power
Feature
Power supply
HP 45 W Smart AC adapter
Primary battery
2-cell, 37.69 Wh Li-ion polymer
Battery life
Up to 11 hours
Windows 10 MM14 battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Power cord
1.0 m (3.28 ft) with sticker label
Physical specifications
Feature
Dimensions (W X D X H)
30.0 x 1.80 x 1.80 cm (11.81 x 0.71 x 0.71 in)
1.29 kg (2.84 lb)
Weight varies by configuration.
Country: Flag Bulgaria
