Samsung MultiXpress MFP SL-K4250-K4350, Color MFP SL-X4220-X4300 - ID Card Copying
The printer can print two-sided originals on one sheet.
Figure : Output
The printer prints one side of the original on the upper half of the paper and the other side on the lower half without reducing the size of the original. This feature is helpful for copying a small-sized item such as business card.
The original must be placed on the scanner glass to use this feature.
  1. Tap ID Copy from the home screen or Apps.
  2. If necessary, adjust the settings for each copy such as Print Layout, Original Size, Paper Source, Adjust to Paper Size, and Align. Follow the instructions on the control panel.
  3. Place the front side of an original facing down on the scanner glass where arrows indicate as shown, then close the scanner lid.
    Figure : Scan front side
  4. Touch Start. The printer begins scanning the front side.
  5. Turn the original over and place it on the scanner glass where arrows indicate as shown, then close the scanner lid.
    Figure : Scan back side
  6. Touch Start. The printer begins scanning the back side.
    • If users do not touch the Start button, only the front side will be copied.
    • If the original is larger than the printable area, some portions might not be printed.
