This document provides information on how to use the Near Field Communication (NFC) feature on Samsung printers to print documents from an Android mobile device.
note:The NFC feature is available only on select Wi-Fi printer models. To add this feature on a wireless networking printer, you might have to contact the purchasing point to order a wireless/NFC kit, and then install the kit using the Installation Guide.
Follow these steps to use the NFC feature on the printer:
