Samsung ProXpress SL-M3820, SL-M4020 - Opening Printer Preferences
This document shows you the available printing preferences and the various options within each preference.
When you select an option in Printing Preferences, you may see a warning mark, , or . An exclamation mark means you can select the specific option but it is not recommended, and an mark means you cannot select that option with the current settings or environment.
