Samsung MFP SCX-4621 - Setting the Paper Size and Type
After loading paper in the tray, setting the paper size and type using the control panel buttons is required. These settings will apply to copy and fax modes. For PC-printing, the paper size and type in the application program must be selected that is used on the PC.
  1. Press Menu. The display shows Paper Setting on the top line of the display.
  2. Press the scroll button ( < or > ) to display Paper Size on the bottom line and press Enter to access the menu item.
  3. Use the scroll button ( < or > ) to find the paper size being used and press Enter to save it.
  4. Press the > button to scroll to Paper Type and press Enter to access the menu item.
  5. Use the scroll button ( < or > ) to find the paper type being used and press Enter to save it.
  6. To return to Standby mode, press Stop/Clear.
