Product Specifications for the HP ENVY 5030 All-in-One Printer (M2U92B)
Product naming
Model name
M2U92B
What's included and accessories
What's in the box
HP OfficeJet 5230 All-in-One Printer; HP 304 Black Original Ink Cartridge (~120 pages); HP 304 Tri-colour Original Ink Cartridge (~100 pages); Ink flyer; Power cord.
Connectivity
Ports
1 Hi-Speed USB 2.0; 1 Wi-Fi 802.11 b/g/n (dual band)
Wireless capability
Yes
Copy
Copier settings
Start black copy, start colour copy, number of copies, 2-sided, paper type, resize, ID card copy, lighter/darker
Color copy capability
Yes
Copy resolution
600 x 300 dpi
Environmental
Non-Operating humidity range
20 to 80% RH non-condensing
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140ºF
Environmental specifications
Save paper by up to 50% using automatic two-sided printing. Western Europe: Original HP 301 cartridges contain up to 70% recycled plastic. CISMEA: Original HP 122 cartridges contain up to 70% recycled plastic. Free, convenient cartridge recycling in 48 countries. More information at http://www.hp.com/recycle
Fax
Modem
56 kbps
Memory
Memory
256 MB DDR3L memory
Maximum memory
256 MB DDR3L memory
Mobile printing capability
Mobile printing services
Features wireless direct and local Wi-Fi connectivity to enable mobile printing via HP ePrint, Apple AirPrint as well as other solutions; Mopria-certified. Supports printing from most smartphones and tablets using these operating systems: Android, iOS, Blackberry, Symbian, Windows 8, Windows RT.
Networking
Network protocols, supported
TCP/IP
Paper handling
Input capacity
Up to 100 sheets
Standard input capacity (cards)
Up to 40 cards
Standard input capacity (envelopes)
Up to 10 envelopes
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media sizes supported (U.S. standard)
Letter; Legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
Simplex: 76.2 x 127 mm to 216 x 594 mm; Duplex: 76.2 x 127 mm to 216 x 594 mm
Media sizes, custom (U.S. standard)
Simplex: 3 x 5 to 8.5 x 14; Duplex: 3 x 5.5 to 8.5 x 12.2 in
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers; Plain Paper; Light/Recycled
Media weight supported (metric)
64 to 90 g/m
Media weight supported (U.S. standard)
16 to 23 lb
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Physical dimensions
Maximum dimensions (W x D x H, metric)
445 x 564 x 128 mm
Maximum dimensions (W x D x H, U.S. standard)
17.53 x 22.22 x 5.04 in
Weight (metric)
5.41 kg
Weight (U.S. standard)
11.93 lb
Power
Built-in Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz, 0.7A
Power consumption
Up to 14 watts (Printing), 3.75 watts (Ready), 0.89 watts (Sleep), 0.11 watts (Off)
Print cartridges
Number of print cartridges
2 (1 black, 1 tri-colour - cyan, magenta, yellow)
Replacement cartridges
N9K06AE HP 304 Black Original Ink Advantage Cartridge (~120 pages); N9K05AE HP 304 Tri-colour Original Ink Advantage Cartridge (~100 pages); N9K08AE HP 304XL High Yield Black Original Ink Advantage Cartridge (~300 pages); N9K07AE HP 304XL High Yield Tri-colour Original Ink Advantage Cartridge (~300 pages)
Printing specifications
Duplex printing
Automatic (standard)
Print speed black (ISO)
Up to 10 ppm
Print speed color (ISO)
Up to 7 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Maximum print area (metric)
215.9 x 355.6 mm
Maximum print area (U.S. standard)
8.5 x 14 in
Monthly duty cycle
Up to 1250 pages
Print languages
HP PCL3 GUI
Regulatory specifications
Safety
IEC 60950 -1:2005+ A1:2009+ A2:2013/EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013; IEC 62479:2010/EN 62479:2010; IEC 62311:2007/EN 62311:2008; Radio Equipment Directive 2014/53/EU with CE Marking (Europe); Other safety approvals as required by individual countries.
Electromagnetic compatibility
CISPR 32:2012/EN 55032:2012 (Class B), CISPR24:2010/EN 55024:2010, EN 301 489-1 v2.1.1:2017, EN 301 489-17 v3.1.1:2017, EN 61000-3-2:2014, EN 61000-3-3:2013, Radio Equipment Directive 2014/53/EU with CE Marking (Europe)
Telecom compliance (fax capability)
Telecom (Wireless): Radio Equipment Directive 2014/53/EU with CE Marking (Europe); EN 300 328 V2.1.1; EN 301 893 V 1.8.1 and V2.1.0 (Notified Body Certificate Number: A104712); Other Telecom approvals as required by individual countries
Scan
Scan technology
CIS
Scan speed (normal)
3 ppm colour, 7 ppm monochrome
Scan resolution, hardware
Up to 1200 x 1200
Levels of grayscale
256
Scanning options (ADF)
No
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista (32-bit only): 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Recommended system requirements for Windows
Minimum system requirements for Macintosh
Mac OS X v10.12 (Sierra), v10.11 (EI Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Recommended Macintosh system requirements
Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Compatible network operating systems
Windows 10, 8, 7, Vista, XP SP3 or higher (32-bit only), Win Server 2008 R2 and higher (via the command line installer), Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite)
One-year limited hardware warranty
