Samsung MFP SL-K3250-K3300, MultiXpress Color MFP SL-X3220-X3280 - Printing on Special Paper
The table below shows the available special paper for each tray.
When using special paper, HP recommends feeding one piece of paper at a time. Check the maximum input number of paper for each tray, see Print paper specifications.
Types (A4)
Standard tray and optional dual cassette feeder
Multipurpose tray
Plain
X
X
Thick
X
X
Heavy weight
X
X
Extra heavy weight
X
Thin
X
X
Cotton
X
X
Colored
X
X
Preprinted
X
X
Recycled
X
X
Bond
X
X
Archive
X
X
Letterhead
X
X
Hole punched
X
X
Thin cardstock
X
X
Thin glossy
X
X
Envelope
X
Labels
X
X: Supported
Blank: Not supported
The paper types are shown in the Printing Preferences. This paper type option allows setting the type of paper to be loaded in the tray. This setting appears in the list so that it can be selected. This allows for the best quality printout. If not, the desired print quality might not be achieved.
Envelope
Successful printing on envelopes depends upon the quality of the envelopes. To print an envelope, place it with the flap side up.
Figure : Flap side up
  • When selecting envelopes, consider the following factors:
    • Weight: The weight of the envelope paper does not exceed 90 g/m2 (16 lb.) otherwise, a jam might occur.
    • Construction: Prior to printing, envelopes must lie flat with less than 6 mm (0.25 inches) curl, and do not contain air.
    • Condition: Envelopes are not wrinkled, nicked, or damaged.
    • Temperature: Use envelopes that are compatible with the heat and pressure of the printer during operation.
  • Use only well-constructed envelopes with sharp and well-creased folds.
  • Do not use stamped envelopes.
  • Do not use envelopes with clasps, snaps, windows, coated lining, self-adhesive seals, or other synthetic materials.
  • Do not use damaged or poorly made envelopes.
  • Be sure the seam at both ends of the envelope extends all the way to the corner of the envelope.
      Figure : Seams
    1. Acceptable
    2. Unacceptable
  • Envelopes with a peel-off adhesive strip or with more than one flap that folds over to seal must use adhesives compatible with the printer’s fusing temperature of about 170°C (338 °F) for 0.1 second. The extra flaps and strips might cause wrinkling, creasing, or jams, and might even damage the fuser.
  • For the best print quality, position margins no closer than 15 mm (0.6 inches) from the edges of the envelope.
  • Avoid printing over the area where the envelope’s seams meet.
Labels
Load the paper with the side to be printed on facing down. To avoid damaging the printer, use only labels designed for use in laser printers.
Figure : Labels face down
  • When selecting labels, consider the following factors:
    • Adhesives: The adhesive material needs to be stable at the printer’s fusing temperature of about 170°C (338 °F) for 0.1 second.
    • Arrangement: Only use labels with no exposed backing between them. Labels might peel off sheets that have spaces between the labels, causing serious jams.
    • Curl: Prior to printing, labels must lie flat with no more than 13 mm (0.5 inches) of curl in any direction.
    • Condition: Do not use labels with wrinkles, bubbles, or other indications of separation.
  • Make sure that there is no exposed adhesive material between labels. Exposed areas might cause labels to peel off during printing, which might cause paper jams. Exposed adhesive might also cause damage to printer components.
  • Do not run a sheet of labels through the printer more than once. The adhesive backing is designed for only a single pass through the printer.
  • Do not use labels that are separating from the backing sheet or are wrinkled, bubbled, or damaged.
  • Do not load paper that does not have space between labels running the same direction as the paper is being fed. Otherwise, it might cause paper jams.
    Figure : Label spacing
Card stock and custom-sized paper
Figure : Card stock and custom paper
  • Do not print on paper smaller than 98 mm (3.8 inches) wide or 148 mm (5.8 inches) long.
  • In the software application, set margins to at least 6.4 mm (0.25 inches) away from the edges of the material.
Letterhead and preprinted paper
Tray
Single-sided
Double-sided
Face up
Face down
Multipurpose tray
Face down
Face up
  • Preprinted paper must be printed with heat-resistant ink that will not melt, vaporize, or release hazardous emissions when subjected to the printer’s fusing temperature of about 170°C (338 °F) for 0.1 second.
  • Preprinted paper ink must be non-flammable and not adversely affect printer rollers.
  • Seal forms in a moisture-proof wrapping to prevent changes during storage.
  • Before loading preprinted paper, verify that the ink on the paper is dry. During the fusing process, wet ink might come off preprinted paper, reducing print quality.
