HP OfficeJet Pro 7740 Printers - Use High Capacity Cartridges after Update
A new firmware upgrade, released on August 16, 2017, makes HP Officejet Pro 7740 printers compatible with HP 956XL/957XL/958XL/959XL Ink Cartridges.
By default, if the printer is connected to a network and Web Services has been enabled, the printer automatically checks for updates.
To update the printer using the printer control panel, follow these steps:
  1. From the top of the screen, touch or swipe down the tab to open the Dashboard.
  2. Touch (Setup).
  3. Touch Printer Maintenance.
  4. Touch Update the Printer.
  5. Touch Check for Printer Updates Now.
