Samsung Laser Printers - Linux Printing
Some features may not be available, or supported, depending on your printer model or its options.
Printing from applications
There are many Linux applications that allow you to print using Common UNIX Printing System System (CUPS). Your printer can print from any of the Linux print applications.
1
Open the document to print.
2
Open the File menu, and then click Page Setup (Print Setup for some applications).
3
Choose your paper size, orientation, and make sure that your printer is selected. Click Apply.
4
Open the File menu, and then click Print.
5
Select your printer to print.
6
Choose the number of copies and indicate which page numbers to print.
7
Change other printing options in each tab, if necessary.
8
Click Print.
Automatic/manual duplex printing may not be available depending on printer models. You can alternatively use the lpr printing system, or other applications, for odd-even printing (see "Features by model" in your printer's User Guide).
Printing files
You can print text, image, or pdf files on your printer using the standard CUPS directly from the command line interface. The CUPS lp or lpr utility allows these printing choices. You can print these files by using the command format below:
"lp-d <printer name> -o <option> <file name>"
Refer to lp or lpr man page on your system for more details.
Configuring printer properties
The default printing options, or connection type, can be changed using the Printing utility supplied by the operating system.
1
Launch Printing utility (Go to System > Administration > Printing menu or execute "system-config-printer" command in Terminal program).
2
Select your printer and double-click it.
3
Change default printing options, or connection type.
4
Click Apply button.
