Figure : HP VH240a 23.8-inch Monitor
Specification
Type
23.8-inches, IPS
Viewable image area
(diagonal)
60.45 cm (23.8 in) widescreen
Panel active area (W x H)
52.70 x 29.67 cm (20.75 x 11.68 in)
Resolution
1920 x 1080 at 60 Hz
note: |
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal
Up to 178° vertical
Brightness (typical)
250 cd/m2
Contrast ratio (typical)
1000:1 static
Dynamic contrast ratio (typical)
5,000,000:1 dynamic (DCR)
Response times (typical)
5 ms Gray to Gray
Pixel pitch
0.275 x 0.275 mm
Pixels Per Inch (PPI)
92.55
Default color temperature
6500 K
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut (typical)
72% sRGB
Color production
Displays up to 16.7 million colors
note: |
Anti-glare panel
Yes
note:Actual performance varies.
Specification
Buttons or switches
Menu/OK
Information/Minus ("-")
Viewing Modes/Plus ("+")
Auto adjustment (VGA)/Brightness/Exit
Power button
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display
(OSD)
user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Specification
Native resolution
Preset graphic modes/supported resolutions
640 x 480 at 60Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Maximum pixel clock speed
170 MHz
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 80 kHz
Specification
Plug and play
Yes
Input connectors
(1) VGA
(1) HDMI (HDCP supported)
Video cables included
(1) VGA cable 1.8 m (5.9 ft)
Multimedia
Speakers
Yes, Dual
2 Watts per channel
Specification
Color
Black
Detachable stand
Yes
Tilt range
-5° to +30° vertical
Swivel
Yes
360°
Pivot
Yes
Security lock-ready
Yes
note:Not available on head only model.
Specification
Power supply
External
Input power
100 - 240 VAC at 50/60 Hz
Maximum power
25 W
Typical power
20 W
Power saving
0.5 W
Power cable length
1.9 m (6.23 ft)
Specification
Dimensions
(W × D × H)
Unpacked with stand
53.90 x 21.79 x 49.91 cm
(21.22 x 8.58 x 19.65 in)
Packaged
65.51 x 24.99 x 42.01 cm
(25.79 x 9.84 x 16.54 in)
Unpacked without stand (head only)
53.90 x 4.60 x 32.31 cm
(21.22 x 1.81 x 12.72 in)
Unpacked with stand
4.66 kg (10.27 lb)
Packaged
7.2 kg (15.87 lb)
Head only
2.55 kg (5.62 lb)
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-34° to 60° C (-29.20° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Mercury-free display backlighting
Yes
White LED backlights
Yes
Low Halogen
Yes
note: |
Eco-label certifications & declarations
Microsoft WHQL certification (Windows 10 RS, Windows 10, Windows 8.1, Windows 8)
ENERGY STAR 7.0 qualified (registration varies by country/region)
EPEAT Silver
CE
CB
TUV-GS
ISO 9241-307
TUV-LBL
Specification
Monitor and accessories
External power supply
Documentation
CD (includes User guide, warranty, and drivers)
HP Display Assistant
