HP Notebook - 17-bs008tx Product Specifications
1ZH67PA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
AMD Radeon™ 530 Graphics (4 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
17.3" diagonal FHD IPS UWVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 2 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
41.5 x 27.8 x 2.46 cm
2.71 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP JumpStart; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
