Document ID: c05604217
Version: 1
Advisory: HP ThinClients t420 and t520 - Blast Desktop Session Screen is Black
Release date : 25-Jul-2017
Last updated : 26-Jul-2017
DESCRIPTION
When connecting to a Blast desktop, the session screen is black.
This occurs if H.265 is enabled.
SCOPE
HP ThinClient T520 with limited graphic frame buffer size.
Systems:
  • HP t420 Thin Client Series
  • HP t520 Flexible Thin Client series
Operating Systems:
  • HP ThinPro Operating System
RESOLUTION
Work around the issue as follows:
  1. In BIOS setup, Advanced, Device options, change Integrated Graphics to Force, and change the UMA frame buffer size 512M.
  2. Disable H.264 in VMware-view GUI settings.
  3. Update to TP 6.2 and view client 4.5, and set allowBlacklistedDriver to "0" in Thnregeditor.
Hardware platforms affected : HP t420 Base Model Thin Client, HP t420 Thin Client, HP t420 Thin Client, HP t420 Thin Client (ENERGY STAR), HP t520 Base Model Flexible Thin Client, HP t520 Flexible Thin Client, HP t520 Flexible Thin Client, HP t520 Flexible Thin Client (ENERGY STAR)
Support Communication Cross Reference ID : IA05604217
