Samsung Laser Printers - Supported Mobile Apps
Available apps
  • Samsung Mobile Print: Samsung Mobile Print is a free application that enables users to print, scan (only users with printers that support scan), or fax (only users with printers that support fax) photos, documents, and web pages directly from a smart phone or tablet. Samsung Mobile Print is not only compatible with Android and iOS smart phones, but also with the iPod Touch and tablet PCs. It connects the mobile device to a network connected to a Samsung printer or to a wireless printer through a Wi-Fi access point. Installing a new driver or configuring network settings is not necessary – just install the Samsung Mobile Print application, and it will automatically detect compatible Samsung printers. Besides printing photos, web pages, and PDFs, scanning is also supported. If a Samsung multifunction printer is available, scan any document into a JPG, PDF, or PNG format for quick and easy viewing on the mobile device.
  • Samsung Mobile Print Pro/Control: Helps users to get an authentication easily. This app provides one way of getting a user authentication using a mobile device.
  • Samsung Mobile Print Manager: Enables users to use cloning and wireless setup features using a mobile device.
Downloading apps
To download apps, go to the application store (Play Store, App Store) on the mobile device, and search for Samsung Mobile Print, Samsung Mobile Print Pro/Control, or Samsung Mobile Print Manager. For Apple device visit iTunes on the computer.
    • Android: Search for Samsung Mobile Print from the Play Store, then download the app.
    • iOS: Search for Samsung Mobile Print from the App Store, then download the app.
  • Samsung Mobile Print Pro/Control, Samsung Mobile Print Manager
    • Android: Search for Samsung Mobile Print Pro/Control or Samsung Mobile Print Manager from the Play Store, then download the app.
Supported mobile OS
    • Android OS 2.3, 4.0 or higher
    • iOS 5.0, 8.0 or higher
    • NFC and Wi-Fi Direct enabled, supported mobile apps installed mobile device with Android 4.0 or higher, iOS 8.0 or higher.
