Samsung Laser Printers - Samsung Mobile Print
What is Samsung Mobile Print?
Samsung Mobile Print is a free application than enables users to print photos, documents, and web pages directly from a smart phone or tablet. Samsung Mobile Print is not only compatible with Android and iOS smart phones, but also with the iPod Touch and tablet PCs. It connects to the mobile device to a network connected Samsung printer or to a wireless printer through a Wi-Fi access point. Installing a new driver or configuring network settings is not necessary–just simply install the Samsung Mobile Print application and it will automatically detect compatible Samsung printers. Besides printing photos, web pages, and PDFs, scanning is also supported. If it is a Samsung multifunction printer, scan any document into a JPG, PDF, or PNG format for quick and easy viewing on the mobile device.
Downloading Samsung Mobile Print
To download Samsung Mobile Print, go to the application store (Samsung Apps, Play Store, App Store) on the mobile device, and search for Samsung Mobile Print. For Apple devices visit iTunes on the computer.
Figure : Android
Figure : iOS
  • Samsung Mobile Print
    • Android: Search for Samsung Mobile Print from the Play Store, then download the app.
    • iOS: Search for Samsung Mobile Print from the App Store, then download the app.
Supported mobile OS
  • Android OS 2.1, 2.3 or higher
  • iOS 4.0, 7.0 or higher
Supported devices
  • iOS 4.0 or higher: iPod Touch, iPhone, iPad
  • Android 2.1 or higher: Galaxy S series, Galaxy Note series, Galaxy Tab series, Galaxy Camera series, and Android mobile device
  • Android 2.3 or higher: Galaxy series and Android mobile devices
Using the Samsung Mobile Print app
Samsung Mobile Print is a free application that enables users to print, scan (only users with multi-functional printers), or fax (only users with multi-functional printers) photos, documents, and web pages directly from a smart phone or tablet.
Printing
  1. Check that NFC and Wi-Fi Direct features are enabled on the mobile device and the Wi-Fi Direct feature is enabled on the printer.
  2. Open the Samsung Mobile Print app.
    If Samsung Mobile Print is not installed on a cell phone, go to the application store (Samsung Apps, Play Store, App Store) on the mobile device, and search for Samsung Mobile Print, then download the app and try again.
  3. Select print mode.
  4. Select the content you want to print. If necessary, change the print option by pressing the icon.
  5. Tag the mobile device (usually located on the back of the mobile device) over the NFC tag on the printer. Wait a few seconds for the mobile device to send a job to the printer.
    Figure : NFC tag
    For some mobile devices, the NFC tag might not be located at the back of the mobile device. Check the location of the NFC antenna on the mobile device before tagging.
  6. The printer starts printing.
Scanning
  3. Select scan mode.
  4. Place a single document face down on the document glass, or load the documents face up into the document feeder. If necessary, change the scan option by pressing the icon.
    Figure : NFC tag
  6. The printer starts scanning the content. The scanned data is saved on the mobile device.
    To continue scanning, follow the instructions on the app screen.
Sending fax
  3. Select fax mode.
  4. Select the content to send via fax. If necessary, enter the fax number and change the fax option by pressing the icon.
    Figure : NFC tag
  6. The printer starts faxing the content.
