Samsung Multifunction Laser Printers - Receive Faxes Using DRPD Mode
This document shows you how to receive faxes using DRPD mode.
Use these steps to set up your printer to receive faxes using DRPD mode.
  1. Turn the printer power on.
  2. Press the Fax button on the control panel.
  3. Press the Menu button on the control panel.
  4. Using the left and right arrows select Fax Setup, then press OK.
  5. Using the left and right arrows select Receiving, then press OK.
  6. Navigate to DRPD mode, then press Waiting Ring.
  7. Call your fax number from a different telephone number.
    When the printer begins to ring, do not answer. The printer requires several rings to learn the pattern.
  8. Once completed, Completed DRPD Setup displays on the control panel.
    Error DRPD ring displays if the DRPD set up fails. If this occurs, power the printer off, then back on. Repeat the steps above to set up DRPD mode.
  9. Press the Stop/Clear button to exit or press OK when DRPD appears to go through set up again.
    DRPD must be set up again if the printer is assigned a new fax number or another phone line is connected.
