1ZB08EA
HP ENVY - 17-ae005ur
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (2 x 4 GB)
Video graphics
NVIDIA® GeForce® 940MX (2 GB GDDR5 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
41.6 x 28.3 x 2.33 cm
2.9 kg
65 W AC power adapter
3-cell, 55.8 Wh Li-ion
HP Wide Vision FHD IR Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
