Samsung Laser Printers - How to Install Drivers/Software Using the Samsung Printer Software Installers for Mac OS X
The Samsung Printer Software Installer is a web-based installer that will download and install the printer drivers and software needed for the Samsung printer currently connected.
If you have not installed the print driver yet, go to Software and Driver Downloads and type your printer model into the search text box to download the latest driver.
Figure : Example of the Samsung Printer Software Installer
Image shows Samsung Printer Software Installer
Once the Installer opens, click the Mac OS X icon if your operating system is Mac OS X 10.5 or higher.
Mac OS X
Select your type of installation, and follow the appropriate steps.
