    Apache Log4j Update
HP Notebook - 14-bs027ur Product Specifications
2CN70EA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
6 GB DDR4-2133 SDRAM (1 x 2 GB, 1 x 4 GB)
Video graphics
AMD Radeon™ 520 Graphics (2 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
35.6 cm (14") diagonal HD SVA anti-glare WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.0 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 VGA; 1 RJ-45; 1 headphone/microphone combo
34 x 24 x 2.37 cm
1.9 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 1.2
