HP Spectre x360 - 13-ac086tu Product Specifications
2GU92PA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
  • Intel® HD Graphics 620
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS WLED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 headphone/microphone combo; 2 USB 3.1 Type-C™ Gen 2 (Thunderbolt, Data up to 40 GB/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 (HP Sleep and Charge)
30.7 x 21.8 x 1.39 cm
1.32 kg
65 W AC power adapter
3-cell, 57.8 Wh Li-ion
HP TrueVision FHD IR Camera with dual array digital microphone
Bang & Olufsen, quad speakers, HP Audio Boost
HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect
Pre-installed software
User Guide documentation
