HP 22w 21.5-inch Display - Product Specifications
The HP 22w is a 54.6 cm (21.5 in) Display.
Figure : HP 22w Display
The HP 22w Display
1CA83AA
Technical specifications
LED feature
Specification
Display size
54.6 cm (21.5 in) diagonal
Display type
IPS with LED Backlight
Panel active area
47.6 x 26.8 cm (18.7 x 10.6 in)
Brightness
250 cd/m²
Color gamut
72%
Color Support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.24795 (H) x 0.24795 (V) mm
102.46 PPI
Inputs
1 VGA
1 HDMI
HDCP support
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Scan range
Horizontal: 30 to 80 KHz
Vertical: 50 to 60 Hz
Recommended resolution
1920 x 1080 @ 60 Hz
Aspect ratio
16:9
Static contrast ratio
1000:1
Dynamic contrast ratio
5,000,000:1
Response time
5 ms GtG
Power consumption
21 W max
Tilt
-5 to +23 degrees
Power Supply
Internal
Dimensions
W x D x H (unpacked):
49.0 x 17.6 x 38.1 cm (19.3 x 6.9 x 6.8 in)
Unpacked: 3.1 Kg (6.9 lbs)
