HP PageWide Enterprise MFP, HP PageWide Managed MFP - Replace the staple cartridge in the inner finisher (dns, zs, zts models)
  1. Open the stapler door.
    Figure : Open the stapler door
  2. Pull the colored handle on the staple cartridge, and then pull the staple cartridge straight out.
    Figure : Remove the staple cartridge
  3. Insert the new staple cartridge into the stapler and push on the colored handle until it snaps into place.
    Figure : Insert the staple cartridge
  4. Close the stapler door.
    Figure : Close the stapler door
