HP ENVY x360 - 15-bq000no Product Specifications
1PB50EA
AMD Quad-Core A12-9720P APU (2.7 GHz base frequency, up to 3.6 GHz burst frequency, 2 MB cache)
8 GB DDR4-1866 SDRAM (2 x 4 GB)
Video graphics
  • AMD Radeon™ R7 Graphics
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI v2.0a; 1 headphone/microphone combo
35.97 x 24.88 x 1.96 cm
2.06 kg
45 W AC power adapter
3-cell, 55.8 Wh Li-ion
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Sure Connect
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
