HP Pavilion x360 - 14-ba051tx Product Specifications
2DP13PA
Intel® Core™ i3-7100U (2.4 GHz, 3 MB cache, 2 cores)
Flash cache
8 GB
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
  • NVIDIA® GeForce® 940MX (2 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
14" diagonal HD SVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ Gen 1 (Data up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
33.48 x 22.69 x 1.99 cm
1.72 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers; B&O PLAY; HP Audio Boost
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP JumpStart; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
