    We are upgrading our website
    If you experience errors during this time, please try again later. Sorry for the inconvenience.
    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP AMP 100 Printers - Replacing Ink Cartridges
This document is for HP AMP 100, 120, 125, and 130 printers.
This document contains steps for replacing the ink cartridges.
Step 1: Replace the ink cartridges
Replace any low or empty ink cartridges.
If you are enrolled in the HP Instant Ink program, you receive special HP Instant Ink cartridges. Some HP Instant Ink cartridges are larger than standard ink cartridges, but they fit in the carriage in the same way. HP Instant Ink is not available in all countries/regions or for all printer models. For more information, go to HP Instant Ink.
    HP Instant Ink and standard ink cartridges
  1. Standard ink cartridge
  2. HP Instant Ink cartridge
  1. Turn on the printer.
  2. Open the ink cartridge access door.
    Opening the ink cartridge access door
  3. Wait until the carriage stops moving before you continue.
  4. Gently press down on the ink cartridge to release it, and then pull the ink cartridge out of its slot.
    Removing the ink cartridge
  5. Remove the new ink cartridge from its package. Be careful to only touch the black plastic on the ink cartridge.
    Removing the ink cartridge from its package
  6. Remove the plastic tape from the ink cartridge.
    Removing the plastic tape
  7. Hold the ink cartridge by its sides with the contacts toward the printer, insert the ink cartridge into its slot, and then gently push the ink cartridge until it snaps into place.
    Install the color ink cartridge on the left and the black ink cartridge on the right.
    Snapping the ink  cartridge into place
  8. Repeat these steps for the other ink cartridge, if necessary.
  9. Close the ink cartridge access door.
    Closing the ink cartridge access door
Step 2: Align the ink cartridges
For best print quality, align the ink cartridges.
Refer to these frequently asked questions about replacing the ink cartridges.
