HP PageWide Pro 750, MFP 772, 777 - Send a fax using monitor dialing
When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the printer. This enables you to respond to prompts while dialing, as well as control the pace of your dialing.
Make sure the volume is turned on to hear a dial tone.
If you are using a calling card and do not enter your PIN fast enough, the printer might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, create a phone book contact to store the PIN for your calling card.
To send a fax using monitor dialing
  1. Load your original print-side down on the scanner glass or print-side up in the automatic document feeder.
    For more information, see Load the scanner or Load the document feeder.
  2. On the control panel, touch the Fax icon.
  3. In the display, touch the Send Now icon, and follow the onscreen instructions.
  4. For a color fax, touch Settings, and then Color/Black and Send Fax as Color.
  5. Touch Send.
  6. When you hear the dial tone, enter the number by using the keypad on the printer control panel.
  7. Follow any prompts that might occur.
    If you are using a calling card to send a fax and you have your calling card PIN stored as a phone book contact, when prompted to enter your PIN, touch (Phone Book) to select the phone book contact where you have your PIN stored.
    Your fax is sent when the receiving fax machine answers.
Country: Flag Bulgaria
