    Fix Windows 10 Update Issues
HP PageWide Pro 750, MFP 772, 777 - Print from a USB device
This product features printing directly from a USB storage device (Plug and Print), so you can quickly print files without sending them from a computer. The product accepts standard USB storage accessories in the USB port near the control panel.
  1. Insert the USB device into the USB port on the front of the product. The Memory Device Options menu opens.
  2. In the display, touch the Print Documents icon.
  3. Navigate to the job you want on the USB device, and open it.
    You can print the following types of files:
    • PDF
    • All photo formats
    • Microsoft Office files, except Excel
  4. Select the number of copies, and touch Black or Color to start printing.
