HP PageWide Pro 750, MFP 772, 777 - Load Tray 2 (single) or Trays 2/3 (tandem)
Depending on the product model, the default tray is Tray 2 (single) or Tray 3 (tandem). When loading paper into the product for the first time, load the default tray first.
If you are not using Alternate Letterhead Mode (ALM), place the paper as follows for one-sided printing:
  • A4/Letter sized: Place portrait-oriented paper with the side to be printed on face-down, with the top edge toward the back of the tray.
  • A3/Ledger sized: Place landscape-oriented paper with the side to be printed on face-down, with the top edge toward the left.
For ALM orientation, see Load letterhead or preprinted forms.
  1. Pull the tray out of the product.
  2. Open the paper length and width guides completely.
  3. Place the paper in the tray and make sure that it is flat at all four corners. Close the length and width paper guides against the loaded media.
  4. Push down the paper to make sure that the stack is below the stack-height indicator on the back of the tray.
  5. Put the tray into the product.
If you have a tandem tray, repeat these instructions to load paper into the other tray.
