HP PageWide Pro 750, MFP 772, 777 - Set or change the product password
Use the HP Embedded Web Server to set a password or change an existing password for a product on a network so unauthorized users cannot change the product settings.
For information about protecting your product password, see the Security Best Practices document on the HP secure printing website.
  1. Obtain the product IP (on the control panel dashboard, touch [Ethernet]).
  2. Type the product IP address into the address bar of a web browser. Click the Settings tab, click Security, and then click the General Security link.
    If a password has previously been set, you are prompted to type the password. Type “admin” for User Name along with the password, and then click Apply.
  3. Type the new password in the Password field and in the Confirm Password field.
  4. At the bottom of the window, click Apply to save the password.
