HP PageWide Pro 750, MFP 772, 777 - Factory-set defaults
Restoring the factory-defaults clears all customer data such as fax header, phonebook, and pages stored in memory. The procedure also returns many product settings to factory defaults and then automatically restarts the product.
Restoring the factory-defaults clears all customer data. The procedure also returns many product settings to factory defaults and then automatically restarts the product.
  1. On the control panel, touch the Support Tools icon.
  2. In the display, touch the Maintenance icon.
  3. Scroll to the bottom of the list, and then touch Restore Factory Defaults.
  4. In the menu that appears, touch Restore Factory Defaults again.
  5. Follow the prompts on the control panel.
    The product automatically restarts.
