HP PageWide Pro 750, MFP 772, 777 - HP Embedded Web Server
About the EWS
This product is equipped with the HP Embedded Web Server (EWS), which provides access to information about product and network activities. EWS serves up webpages that can be viewed in a standard web browser.
The EWS resides on a hardware device (such as an HP  printer) or in firmware, rather than as software that is loaded on a network server.
The advantage of the EWS is that it provides an interface to the product that anyone with a network-connected product and computer can use. There is no special software to install or configure, but you must have a supported web browser on the computer. To gain access to the EWS, type the IP address for the product in the address bar of the browser.
About cookies
The EWS places very small text files (cookies) on your hard drive when you are browsing. These files let the EWS recognize your computer the next time you visit. For example, if you have configured the EWS language, a cookie helps remember which language you have selected so that the next time you access the EWS, the pages are displayed in that language. Though some cookies are cleared at the end of each session (such as the cookie that stores the selected language), others (such as the cookie that stores customer-specific preferences) are stored on the computer until you clear them manually.
The cookies that the EWS stores on your computer are used only for saving settings on your computer or for sharing information between the printer and the computer. These cookies are not sent to any HP websites.
You can configure your browser to accept all cookies, or you can configure it to alert you every time a cookie is offered, which allows you to decide which cookies to accept or refuse. You can also use your browser to remove unwanted cookies.
Depending on your printer, if you disable cookies, you also disable one or more of the following features:
  • Starting where you left the application (especially useful when using setup wizards).
  • Remembering the EWS browser language setting.
  • Personalizing the EWS home page.
For information about how to change your privacy and cookie settings and how to view or delete cookies, see the documentation available with your web browser.
Open the EWS
To open the EWS, do one of the following:
  • In a supported web browser, type the product IP address into the address box. (To obtain the IP address, on the control panel dashboard, touch [Ethernet].)
  • In the printer software, open the HP Printer Assistant and on the Print tab, click Printer Home Page (EWS).
    In the printer software, open the HP Printer Assistant and on the Print tab, of the Print, Scan & Fax tab, click Printer Home Page (EWS).
    For more information, see Open the HP Printer Assistant.
  • In OS X, use HP Utility or click System Preferences > Printers > HP PageWide Pro MFP 772-777 > Options & Supplies > General > Show Printer Webpage.
    In OS X, use HP Utility or click System Preferences > Printers & Scanners > HP PageWide Pro MFP 772-777 > Options & Supplies > General > Show Printer Webpage.
If an error occurs while opening the EWS, confirm that the proxy settings are correct for your network.
After you open the URL, bookmark it so that you can return to it quickly in the future.
Features
Changing network settings in the EWS might disable some product or product software features.
Home tab
Use the Home tab to access frequently used items from the Web Services, Network, Tools, and Settings tabs.
Use the Home tab to access frequently used items from the Scan, Fax, Web Services, Network, Tools, and Settings tabs.
Not all of the following items are visible by default. Use the Personalize button to show or hide the items of your choice.
Item
Scan to Email
Configure target email profiles for the scan-to-email feature.
Scan to Network Folder
Configure a target network folder for the scan-to-network feature.
HP Digital Fax
Configure the printer to save faxes to the network or forward them to email.
Energy Save Settings
Configure energy-saving features that switch the printer to Sleep Mode or turn the printer on or off automatically.
Printer Update
Check for new printer updates.
Estimated Cartridge Levels
Review cartridge level status.
Network Summary
View wired (802.3) status or wireless (802.11) status.
Print Quality Toolbox
Run maintenance tools to improve print quality of your printouts.
Wireless Setup Wizard
Set up a wireless connection using the wizard.
Wi-Fi Direct
Set up Wi-Fi Direct to print from a mobile device directly to the printer without connecting to a wireless network.
AirPrint
Set up AirPrint™ for printing from Apple-supported products.
Printer Information
View information about the printer, such as product serial number, service ID, firmware version, and total page count.
Administrator
Set up administrator control of printer features.
Backup
Back up the printer settings into a password-encrypted file.
Fax Log
Display and manage all fax-related activities (including digital fax log).
Fax Setup Wizard
Run the wizard to set up fax features.
Firewall
Configure the network firewall.
Printer Reports
Print the information pages about your printer.
Scan to SharePoint
Configure the target SharePoint folder for the scan-to-folder feature.
Usage Report
Display usage counters for print jobs.
Display usage counters for print, fax, and copy jobs.
Webscan
Enable Webscan, which allows anyone with access to the printer to scan whatever is on the scanner glass.
Settings for this page are automatically saved in the web browser's cookies. If the web browser's cookies are deleted, these settings are lost.
Scan tab
Use the Scan tab to configure the product's scan features.
Item
Scan to Computer
Use Webscan.
For security purposes, Webscan is disabled by default. To enable Webscan, open the Settings tab, click Administrator Settings, select the Enable checkbox beside Webscan, and then click Apply.
When this feature is enabled, anyone with access to the printer can scan whatever is on the scanner glass.
Scan to Email
  • Scan to Email Setup: Use this to set up the Scan-to-Email function and to configure the sender of the scanned documents.
  • Email Address Book: Configure the list of people to whom you can send the scanned documents.
  • Email Options: Configure a default SUBJECT line and body text and configure the default scan settings.
Network Folder Setup: Configure a network folder for saving scanned images or documents from the printer.
Scan to SharePoint
SharePoint Setup: Configure a SharePoint destination for saving scanned documents from the printer.
Scan to USB
Configure the following settings:
  • Scan Settings: Select original size, orientation, darkness, and one- or two-sidedness.
  • File Settings: Select the default file name, file type, color preference, output quality, resolution, and compression.
Address Book
Enter, store, and manage frequently used contact numbers.
Copy/Print tab
Use the Copy/Print tab to configure the product's copy and print features.
Item
Copy Settings
Configure the printer's copy settings, such as the following:
  • Copy Settings: Select settings for one- or two-sided, size, and color.
  • Tray Selection: Set the default paper size and paper type for each tray in the product, and select the default paper tray to use when no tray is specified or when the specified tray is incorrectly loaded.
  • Copy Quality and Enhancements: Select the quality level, lightness/darkness, enhancement mode, collation feature, and binding margin.
Print Settings
Configure general settings for printing (such as quality), duplexing (printing on two sides), PCL fonts, and PostScript errors.
Restrict Color
Set up and manage user access to color printing and copying.
Print tab
Use the Print tab to configure the product's print features.
Item
Print Settings
Restrict Color
Set up and manage user access to color printing.
Fax tab
Use the Fax tab to configure the product's fax features.
Item
Fax Setup Wizard
Configure the printer's fax feature.
Basic Fax Settings
Change the header name/fax number and set other basic fax settings.
Advanced Fax Settings
Set fax details such as Error Reporting, Confirmation, and so on.
Fax Forwarding
Automatically redirect incoming faxes to another fax number.
Junk Fax Blocker
Block faxes from specific people or businesses.
Fax Log: View a list of the faxes that have been sent from or received by this product.
HP Digital Fax
Digital Fax Profile: Save incoming black-and-white faxes to a designated folder on the network or forward them as email.
HP JetAdvantage tab
Use the HP JetAdvantage tab to configure easy-to-use workflow and printing solutions that are both network- and cloud-based. HP JetAdvantage is designed to help your business manage its fleet of printers and scanners.
HP JetAdvantage includes solutions for security, management, workflow, and mobile printing. To enable HP JetAdvantage, make sure the printer is connected to the network and the Internet, and click Continue. Follow the onscreen instructions.
Network tab
Use the Network tab to configure and secure network settings for the product when it is connected to an IP-based network. The Network tab does not appear if the product is connected to other types of networks.
You can enable or disable unused protocols and services. These protocol and services can also be protected from being changed by setting the EWS admin password. For a list of network protocols and services, see Supported network protocols.
Tools tab
Use the Tools tab to view or manage product utilities.
Item
Product Information
  • Printer Information: View information about the printer, such as product serial number, service ID, firmware version, and total page count.
  • Supply Status: Review cartridge level status.
  • Supply Settings: Set the threshold at which the printer provides notifications that cartridges are running low.
Reports
  • Usage Report: View the number of pages processed for printing.
    Usage Report: View the number of pages processed for printing, scanning, copying, and faxing.
  • Printer Reports: Print various reports, such as font lists.
  • Event Log: View the printer's last 50 error messages.
  • Job Log: View a list of the most recent jobs performed by the printer.
  • Color Usage Job Log: View the number of pages printed in black-and-white/grayscale and color for all jobs and for individual jobs.
Utilities
  • Bookmarking: Bookmark pages in the EWS.
  • Print Quality Toolbox: Run maintenance tools to improve the print quality of your printouts.
  • Asset Tracking: Assign an asset number/location to this device.
Backup and Restore
  • Backup: Create a password-encrypted file that stores the printer's settings.
  • Restore: Restore the printer's settings using a backup file created by the EWS.
Printer Restart
Power Cycle: Turn off and restart the printer.
Printer Updates
Firmware Updates: Set up the printer to alert you of updates or to automatically install updates.
Settings tab
Use the Settings tab to set and maintain various options on your product including power management, date and time, email alerts, factory defaults, and firewall settings.
Item
Power Management
Set up the Energy Save mode to minimize the amount of power that the product consumes when idle and to reduce wear on electronic components.
Preferences
Configure the default settings for general printer features such as date and time, language, display, and anonymous usage information. You can also set the default values for specific features such as manual feed, tray and paper management, image registration, ColorLok, and Quiet Mode.
Control Panel Customization
  • Home Screen Customization: Add, remove, or reorder the control panel icons on the printer home screen.
  • Quick Sets: Create sets of commonly used job options, which reduces the need to manually configure settings for each job. Quick Sets display on the control panel.
Security
Configure settings to prevent unauthorized use of the printer or specific printer features. For more information, see Security settings.
Email Alerts
Set the default values for the email server, alert destinations, and alert settings.
Print Settings
Configure default settings for printing (such as font, print quality, duplexing, and black-and-white or color printing).
Restore Defaults
Restore the factory defaults or the network settings.
Firewall
Configure firewall settings such as rules, addresses, services, and other options.
