HP Color LaserJet Enterprise M652, M653, MFP M681, M682 - 13.B9, 13.B2, 13.FF fuser paper jam
Use the following procedure to check for paper in all possible jam locations inside the right door. When a jam occurs, the control panel might display a message and an animation that assists in clearing the jam.
  • 13.B9.XX Jam in fuser
  • 13.B2.XX Jam in <Cover or Door>.
  • 13.FF.EE Door Open Jam
CAUTION: The fuser can be hot while the printer is in use. Wait for the fuser to cool before handling it.
  1. Open the right door.
    Figure : Open the right door
  2. Gently pull out any jammed paper.
    Figure : Remove the jammed paper
  3. If paper is visible entering the bottom of the fuser, gently pull downward to remove it.
    Do not touch the rollers on the transfer roller. Contaminants can affect print quality.
  4. If paper is jammed as it enters the output bin, gently pull the paper downward to remove it.
  5. Paper could be jammed inside the fuser where it would not be visible. Grasp the fuser handles, lift up slightly, and then pull straight out to remove the fuser.
    Figure : Remove the fuser
  6. Open the jam-access door on the fuser. If paper is jammed inside the fuser, gently pull it straight up to remove it. If the paper tears, remove all paper fragments.
    CAUTION: Even if the body of the fuser has cooled, the rollers that are inside could still be hot. Do not touch the fuser rollers until they have cooled.
  7. Close the jam-access door on the fuser, and push the fuser completely into the printer until it clicks into place.
    Figure : Install the fuser
  8. Close the right door.
    Figure : Close the right door
