HP LaserJet M652, M653, E65050, E65060, E65150, E65160, MFP M681, M682, E67550, E67560, E67650, E67660 - Load paper to the 2,000-sheet high-capacity input tray
The following information describes how to load paper into High-capacity input tray. This tray holds up to 2,000 sheets of 75 g/m2 paper.
  1. Open the tray.
    Do not open this tray while it is in use.
    Figure : Open the tray
  2. Before loading paper, adjust the paper-width guide by squeezing the blue adjustment latch and sliding it to the size of the paper being used.
    Figure : Adjust the guides
  3. Rotate the paper-stop lever to the correct position for the paper being used.
    Figure : Adjust the paper-stop lever
  4. Load paper into the tray. Check the paper to verify the guides lightly touch the stack, but do not bend it. For information about how to orient the paper, see the High-capacity input tray paper orientation section below.
    To prevent jams, adjust the paper guides to the correct size and do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    Figure : Load paper
  5. Close the tray.
    Figure : Close the tray
  6. The tray configuration message displays on the printer control panel.
  7. Select the OK button to accept the detected type and size, or select the Modify button to choose a different paper size or type.
Letterhead or preprinted paper
Image orientation
Duplex mode
Paper size
How to load paper
Portrait
1-sided printing
Letter, Legal, A4
Face-up
Top edge at the left side of the tray
Portrait
Automatic 2-sided printing or with Alternative Letterhead Mode enabled
Letter, Legal, A4
Face-down
Landscape
1-sided printing
Letter, Legal, A4
Face-up
Top edge toward the back of the tray
Landscape
Letter, Legal, A4
Face-down
Prepunched paper
Image orientation
Duplex mode
Paper size
How to load paper
Portrait or landscape
1-sided printing
Letter, Legal, A4
Holes toward the back of the tray
Letter, Legal, A4
Use alternative letterhead mode
Use the Alternative Letterhead Mode feature to load letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper or to both sides. When using this mode, load paper as for automatic duplex printing.
To use the feature, enable it by using the printer control-panel menus.
Enable Alternative Letterhead Mode by using the printer control-panel menus
  1. From the Home screen on the printer control panel, navigate to the Settings application, and then select the Settings icon.
  2. Open the following menus:
    1. Copy/Print or Print
    2. Manage Trays
    3. Alternative Letterhead Mode
  3. Select On.
