HP 255 G6 Notebook PC - Specifications
Operating systems
Specification
Preinstalled
Windows 10 Pro 64
Windows 10 Pro 64 (National Academic only)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
FreeDOS 2.0
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
AMD A6-9220 APU
2.5 GHz (up to 2.9 GHz)
1 MB cache
2 cores
AMD Radeon R4 graphics
AMD E2-9000e APU
1.5 GHz (up to 2.0 GHz)
1 MB cache
2 cores
AMD Radeon R2 graphics
AMD System on Chip (SoC)
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of clock speed.
Graphics
Specification
Integrated
Supported
HDMI (cable sold separately)
HD Decode
DX12
Specification
Internal
39.62 cm (15.6 in) diagonal HD SVA eDP anti-glare slim WLED (1366 x 768)
39.62 cm (15.6 in) diagonal FHD SVA eDP anti-glare slim WLED (1920 x 1080)
High-definition (HD) content is required to view high definition images. Resolutions are dependent upon monitor capability, and resolution, and color depth settings.
Storage/drives
Specification
Primary storage SATA, 6.35 cm (2.5 in) hard drives
Supports all 7.2 mm/9.5 mm
1 TB SATA 5400 rpm SATA (7.2/9.5 mm)1
500 GB SATA 5400 rpm SATA (7 mm)1
500 GB SATA 7200 rpm SATA (7 mm)1
M.2 SATA-3 Solid State Drives (SSD)
128 GB M.2 SATA SSD1
256 GB M.2 SATA SSD1
128 GB eMMC (sold separately or as an optional feature)
Optical drives
Optional DVD+/-RW Double-Layer writer (sold separately or as an optional feature)2
1For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
2HD-DVD discs cannot be played on this drive. No support for DVD-RAM.
Memory
Specification
Standard
DDDR4-1866 (transfer rates up to 2133 MT/s)
DDR4-2400 downgraded to DDR4-1866
Single channel support
Not customer accessible/upgradeable
Configurations
4096 MB total system memory (4096 MB x 1)
6144 MB total system memory (2048 MB x 1 + 4096 MB x 1)
8192 MB total system memory (8192 MB x 1)
Maximum
Up to 8 GB
Audio/multimedia
Specification
Audio
(2) Integrated stereo speakers
Dual array microphone
Camera
HP TrueVision HD Camera
Indicator LED
USB 2.0
720p by 30 frames per second
Single digital microphone
HP Webcam
Internet access required.
VGA camera
Indicator LED
USB 2.0
f2.4
480p by 30 frames per second
Keyboard/touchpad
Specification
Keyboard
Full size textured island-style with numeric keypad
Color: Jet black
Touchpad
Multitouch gestures enabled
Supports modern trackpad gestures
Taps enabled as default
Ports/slots
Specification
Ports
(2) USB 3.1 (Gen 1) (left side)
(1) USB 2.0 (right side)
(1) HDMI 1.4b (cable sold separately)
(1) RJ-45/Ethernet (cable sold separately)
(1) VGA port (cable sold separately)
(1) Headphone/microphone combo
(1) AC Smart adapter
Slots
HP Multi-Format digital media card reader
Supports SD/SDHC/SDXC
Networking/communication
Specification
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 3168 802.11ac (1x1) Wi-Fi and Bluetooth 4.2 Combo (non-vPro)
Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the workstation to communicate with other 802.11ac WLAN devices. Actual speed varies.
Ethernet
Integrated 10/100/1000 NIC
Communications
Compatible with Miracast-certified devices
Software/security
Specification
Preinstalled software
Buy Office
HP JumpStart
Discover HP Touchpoint Manager1
Windows 10 Redstone 1 Recovery Manager Installer - CPS
Windows 10 Redstone 1 Push Button Reset Recovery - CPS
HP Support Assistant
HP PC Hardware Diagnostics UEFI
HP ePrint2
HP System Event Utility
CyberLink Power Media Player
Bing Search for Internet Explorer (IE) 11
Security
Trusted Platform Module (TPM) 2.0
Security lock slot (locks sold seperatley)
1Requires subscription and supports Android, iOS and Windows 7 or higher operating systems and PCs, notebooks, tablets and smartphones from various manufacturers. Not available in all countries/regions.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds vary.
Power
Specification
Power supply
45 W Smart AC adapter
65 W EM Smart AC adapter
Availability might vary by country/region.
Power cord
1.0 m (3.28 ft) with sticker label
Primary battery
HP 3-cell battery, 31 Whr Li-ion
HP 4-cell battery, 41 Whr Li-ion
Battery life
Up to 7 hours and 30 minutes (4 cell battery)
Battery life varies depending on various factors including product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Fast charge (90 mins, 90% charged)
Supports battery fast charge
Weight/dimensions
Specification
Starting at 1.86 kg (4.10 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
38.0 x 25.37 x 2.36 cm (14.96 x 9.99 x 0.93 in)
Country: Flag Bulgaria
