    Looking for Site Help?
Sprout Pro by HP G2 - WorkTools Overview
This information applies to WorkTools software included with the Sprout Pro by HP G2.
Sprout Pro by HP G2 has a variety of WorkTools to use. There are WorkTools to align the cameras as well as to capture images and to perform many other functions. This document explains how to open the WorkTools and gives an overview of the functions they perform.
Use the following instructions to open the WorkTools and learn about them.
Launcher
The Launcher is a menu of WorkTools that is accessed by pressing Launcher button on the Sprout Connector. The Connector buttons are directly below the front monitor and are on the part that connects the touchmat to the base of the computer.
Tap the Launcher button to open the Launcher.
Figure : Connector button
Connector buttons with the Launcher button selected
The onscreen Launcher is displayed. From this menu, you can tap the WorkTool you want to open. If the app has not been installed, Sprout launches Discover, where you can install the app.
Figure : Launcher
Launcher from which to choose the app you want to open
Welcome
WorkTools Welcome highlights key Sprout hardware and software features and is an entry point to the WorkTools Control and Discover apps. Go to Discover or Control by tapping the buttons on the bottom or the Welcome page, or tap the right or left arrows on the screen to scroll for additional welcome content.
Figure : Welcome
Welcome
Discover
WorkTools Discover is a central place to learn more about WorkTools and download the latest versions of each WorkTools app. Discover also includes current Sprout promotions, links to download third-party Sprout apps, and tips and tutorials for using Sprout. Content is frequently updated to provide you with the latest available version of the apps.
For more detailed instructions see Sprout Pro by HP G2 - Using WorkTools Discover.
Control
WorkTools Control provides options to adjust Sprout settings, restore Sprout default settings, and to align the projectors with the touchmat.
To open WorkTools Control, tap Control on the Launcher.
Figure : Control
The WorkTools Control opens.
Figure : WorkTools Control
WorkTools Control
Input
WorkTools Input enables a virtual keyboard with palm rejection on the touch mat. This means that when the virtual keyboard is active, everything else on the touchmat is deactivated and a palm rest will not inadvertently activate an action from the touchmat.
To open the virtual keyboard, tap the keyboard button on the Sprout Connector.
Figure : Keyboard button on the connector
The Input virtual keyboard is displayed for use.
Figure : Input virtual keyboard
Stage
You can manage and edit your images in WorkTools Stage. Create different Stages to help organize your content, view your images in Freeform or Grid view, and save your images and Stages for later use.
There are many things you can do in Stage.
  • Drag and drop images from the desktop onto Stage, and from Stage to the desktop and other apps such as MS Office apps or email.
  • Open multiple stages.
  • Open or close navigation bars on the left and right for easy access to commands.
  • Mark or draw on an image with the Ink tool with a finger, stylus, or the HP Active Pen.
  • Group and layer images with the tools.
  • Remove background, autofix, crop, rotate, adjust, and filter with the editing tools.
  • Save and export formats including .STAGE (default), .PNG, .BMP, and .JPG.
For more detailed instructions see Sprout Pro by HP G2 - Using WorkTools Stage
Capture
You can scan objects and documents in 2D using Sprout’s built-in high resolution (14.6 MP) camera and webcam in WorkTools Camera. You can edit your captures and export them to WorkTools Stage or save them in one of several formats.
Editing tools include remove background, crop, rotate, adjust, and filter.
You can save or export your images as .JPG, .PDF, or the default, .PNG.
For more detailed instructions see Sprout Pro by HP G2 - Using WorkTools Capture
Camera 3D
WorkTools Camera 3D is intended for quick real-time 3D scanning projects. You can scan your physical objects in a matter of seconds by holding and rotating the object under the Illuminator to create high-quality 3D models.
The process includes several steps:
  1. Select an object to scan.
  2. Scan the object by rotating it with your hand and moving your fingers as you move it.
  3. Take a Color Capture/Color Refinement of the object to cover the scan for a high-resolution surface.
  4. Finish.
  5. Save as .OBJ (package of .OBJ, .MTL, .JPG) or .3MF (3D Builder) file formats, and use for fun and share with others, or in third-party 3D editing apps.
Successful scanning takes practice. The size of the objects should be between three and eight inches. Smaller or larger objects do not scan well. It is best to keep the object moving steadily as you scan, and if the camera loses track, place the object back down on the touch mat and wait for the camera to be ready to continue.
For more detailed instructions see Sprout Pro by HP G2 - Using Camera 3D
Country: Flag Bulgaria
