HP V214a 20.7-inch Monitor - Specifications
Panel
Specification
Type
TN with LED backlight
Viewable image area
52.58 cm (20.7 in) widescreen; diagonally measured
Active area (W x H)
457.92 x 257.58 mm (18.02 x 10.14 in)
Aspect ratio
16:9
Viewing angle (typical CR>10)
90° horizontal
65° vertical
Brightness (typical)
200 cd/m2
Static contrast ratio
600:1 (typical)
450:1 (minimum)
Dynamic contrast ratio
5,000,000:1
Dynamic contrast ratios during video playback only, depending on series of frames or time duration.
Response rate (typical)
5 ms on/off (typical)
Pixel pitch
0.2385 x 0.2385 mm
Pixels per inch (PPI)
108
Backlight lamp life (to half brightness)
30,000 hours minimum
Default color temperature
Neutral (6500 K)
NTSC
72%
Panel bit depth
6-bit (Hi-FRC)
Actual performance varies.
On screen display
Specification
Buttons or switches
Menu/OK, Minus ("-")/Information, Plus ("+")/Color Control, Next Active Input, Power
User-assignable function buttons
Yes
(4) Function buttons with (1) power button
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
User controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Audio controls
Yes, Volume
Signal interface/performance
Specification
Horizontal scan range
30 - 80 kHz
Vertical scan range
50 - 60 Hz
Native resolution
1920 x 1080 at 60 Hz
Maximum resolution
Recommended resolution
Preset graphic modes
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Maximum pixel clock speed
170 MHz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input connectors
(1) VGA
(1) HDMI 1.4
(1) Audio input
Supports HDCP
Video cable lengths
1.5 m (4.9 ft)
Speakers
Yes - (2) Speakers, 1 W per channel speakers
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
28 W
Typical power
23 W
Power saving
0.5 W
Power cable length
1.9 m (6.23 ft)
Mechanical
Specification
Dimensions (W x D x H)
Unpacked with stand
48.94 x 36.27 x 19.76 cm (19.26 x 14.28 x 7.78 in)
Unpacked without stand
48.94 x 30.06 x 4.8 cm (19.26 x 11.84 x 1.89 x in)
Packaged
55.5 x 12.7 x 39.5 cm (21.85 x 4.99 x 15.35 in)
Head only
2.6 kg (5.73 lb)
Unpacked with stand
3 kg (6.61 lb)
Packaged
4.4 kg (9.7 lb)
Ergonomic features
Specification
Exterior color of monitor bezel and stand
Black
Detachable base
Yes
Tilt range
-5° to +11°
VESA mounting
Yes, 100 mm
Security lock ready
Yes
Environmental
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%, 38.7° C max wet-bulb
Altitude
Operating
0 to 5,000 m (0 to 16,404 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
Arsenic-free display glass
Yes
Mercury-free display backlighting
Yes
EPEAT registered
EPEAT Silver (varies by countries/regions)
ENERGY STAR
Yes, ENERY STAR 7
Agency approvals and certifications
AMS/EMEA application
CB/CE/UL/CSA/FCC/ICES/TUV-GS/ISO 9241-307/Energy Star/WEEE/TUV-Low Blue Light
What's in the box?
Specification
Contents
AC power cord 1.5 m (4.92 ft)
VGA cable 1.5 m (4.92 ft)
Audio cable 1.8 m (5.9 ft)
CD (includes user guide, warranty, and drivers)
