    Apache Log4j Update
HP LaserJet Managed MFP E72525-E72535, E77822-E77830, E78323-E78330 - 13.B2, 13.A3, 13.A8 jam error in tray 2 or tray 3
Use the following procedure to check for paper in all possible jam locations related to tray 2 or tray 3. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.B2.A2 Jam in right door
  • 13.B2.D2 Jam in tray 2
  • 13.A3.A3
  • 13.A3.D3
  • 13.A8.A2 Jam in tray 2
  • 13.A8.D2 Jam in tray 2
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in tray 2 or tray 3.
The printer models referenced in this video might be different from your printer model, but the steps to clear the jam are the same.
The procedure to clear a paper jam in Tray 3 is the same as for Tray 2. Only Tray 2 is shown here.
The fuser can be hot while the printer is in use. Wait for the fuser to cool before handling it.
  1. Open the right door.
    Figure : Open the right door
  2. Gently remove any jammed paper from inside the right door.
    Figure : Remove jammed paper from the right door
  3. Close the right door.
    Figure : Close the right door
  4. Open the tray.
    Figure : Open the tray
  5. Gently remove any jammed or damaged paper from the tray.
    Figure : Removed damaged sheets from the tray
  6. Close the tray. Printing automatically resumes.
    Figure : Close the tray
