HP LaserJet Managed MFP E72525-E72535, E77822-E77830, E78323-E78330 - Load paper to Trays 2 and 3
The following information describes how to load paper in Tray 2 and Tray 3. These trays hold up to 520 sheets of 75 g/m2 (20 lb) paper.
In addition to the instructions provided in this document, you can view the following video of how to load paper in Trays 2 and 3:
The printer models referenced in this video might be different from your printer model, but the steps to clear the jam are the same.
The procedure to load paper to Tray 2 and Tray 3 is the same. Only Tray 2 is shown here.
  1. Open the tray.
    Do not open this tray while it is in use.
    Figure : Open the tray
  2. Before loading paper, adjust the paper-width guides by holding down the blue lock/unlock toggle switch on the rear paper-width guide, pinching the blue adjustment latch on the front paper-width guide, and then sliding the guides to the fully open position.
    Figure : Expand the paper-width guides
  3. Adjust the paper-length guide by pushing in at the bottom of the blue adjustment latch while sliding the guide to the size of the paper being used.
    Figure : Expand the paper-length guides
  4. Load paper into the tray.
    Figure : Load paper in the tray
  5. Adjust the paper-length and paper-width guides to the size of the paper being used. Check the paper to verify the guides lightly touch the stack, but do not bend it.
    Do not adjust the paper guides tightly against the paper stack. Adjust them to the indentations or markings in the tray.
    To prevent jams, adjust the paper guides to the correct size and do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    Figure : Adjust the paper guides to the size of paper being used
  6. Close the tray.
    Figure : Close the tray
    The tray configuration message displays on the printer control panel.
  7. Touch OK to accept the detected type and size, or touch Modify to choose a different paper size or type.
    For custom-size paper, specify the X and Y dimensions for the paper when the prompt displays on the printer control panel.
Trays 2 and 3 paper orientation
Position paper correctly in Trays 2 and 3 to ensure the best print quality.
Letterhead or preprinted paper - Portrait
Duplex mode
How to load paper
1-sided printing
Face-up
Top edge at the back of the tray
Top edge at the left side of the tray
Automatic 2-sided printing or with Alternative Letterhead Mode enabled
Face-down
This is the preferred orientation when printing on A4 or Letter.
Top edge at the right side of the tray
Letterhead or preprinted paper - Landscape
Duplex mode
How to load paper
1-sided printing
Face-up
Face-down
Prepunched paper - Portrait
Duplex mode
How to load paper
1-sided printing
Face-up
Holes at the left side of the tray, with the top of the form at the rear of the printer
Holes at the back of the tray
Face-down
Holes at the right side of the tray
Use alternative Letterhead mode
Use the Alternative Letterhead Mode feature to load Letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper, or to both sides. When using this mode, load paper as for automatic duplex printing.
Enable Alternative Letterhead Mode using the printer control panel
Follow these steps to enable Alternative Letterhead Mode using the printer control panel:
  1. From the Home screen on the printer control panel, navigate to and open the Settings menu.
  2. Open the following menus:
    1. Copy/Print
    2. Manage Trays
    3. Alternative Letterhead Mode
  3. Select On.
