Document ID: c05409699
Version: 1
HP Inc April 2017 System BIOS Refresh
Release date : 02-Mar-2017
Last updated : 02-Mar-2017
DETAILS OF CHANGE
Common changes for all platforms:
  • Fixed an issue where rollback PPI would not pop up after changing the language to non-English from the F10 (BIOS) setup menu.
  • Fixed an issue where the SecureBoot status display in Windows would not align with F10 (BIOS) setup menu.
  • Fixed an issue where computer would not boot with USB Accu-Chek Smartpix connected.
  • Fixed an issue where the computer boot time was longer than 4 minutes when a joystick is connected.
  • Fixed an issue where legacy boot order would be changed when removing a SATA HDD from the computer.
  • Fixed an issue where the boot order could not be changed by BIOSConfigurationUtility.
  • Fixed an issue where POST could not prompt the virtual keyboard for user.
  • Added the Linux repsetup utility support for Intel platforms.
  • Added Linux Flash utility support for Intel platforms.
  • Added a “NumLock on at Boot” feature in the F10 (BIOS) setup menu.
  • Changed instances of "DXE Update" to "BIOS Update."
  • Fixed an issue where PXE Boot would not work when CD-ROM Boot is disabled in BIOS.
  • Added the ability to create a POST Power-On Password when the Administrator Password is unknown.
  • Fixed an issue where PXE would not work in UEFI mode.
  • Fixed an issue where the computer would black screen when booting to legacy SATA ODD.
  • Enabled F1 information to be launched when the BIOS power-on password is set.
  • Fixed an issue where a computer with the NVIDIA NVS 310 graphics card would continuously reboot without a monitor connected.
  • Updated Intel RC code to 2.1.0, MCU to 0x9E for SKL-S/U/Y, and 0xA6 for SKL-H.
  • Fixed an issue where the BIOSConfigurationUtility would show AMT enabled on a non-vPro/AMT CPU.
  • Fixed an issue where the computer would hang when the HP S230tm external touch display was connected using a USB port.
  • Fixed an issue where USB optical drive would not work properly with additional USB Devices.
  • Fixed an issue where the Bitlocker recovery key screen would not be launched when the user forgot their PIN and pressed ESC to enter the Bitlocker recovery key.
  • Added an option in the F10 (BIOS) setup menu to suppress user confirmation prompting.
  • Fixed an issue where UEFI Boot would not boot from an SSD/HDD after the USB key initiated MDT.
  • Fixed an issue where the Touch interface would lag during pre-boot authentication.
  • Fixed an issue where the computer would automatically shutdown when running Heaven BenchMark 4.0 Directx11 3D or OpenGL game in AC mode.
  • Fixed an issue where the WLAN/LAN Switching function would not work on a computer that was upgraded/downgraded from different operating system.
  • Fixed an issue where system would hang during a restart test on Device Guard-enabled system.
  • Fixed an issue where the Electronic Label could not be modified after lock manufacture mode.
  • Added WMI to provide 90B FAN error log.
  • Separated the 90B error into two messages.
HP EliteBook 850/840/820 G3, ZBook 15u G3 Mobile Workstation System BIOS 01.14 has the following enhancements added:
  • Fixed an issue where computer would hang after changing the status of “bios date recovery policy” and “Dynamic runtime scanning of boot block” at same time in the F10 (BIOS) setup menu.
  • Separated the enable/disable external ports option in the F10 (BIOS) setup menu.
  • Fixed an issue where the brightness under Privacy mode could not be adjusted using the fn+f5/f6 keys without the HP Hotkey Support driver installed.
  • Fixed an intermittent stability issue with the Samsung 18nm memory.
HP ZBook Studio G3 Mobile Workstation System BIOS 01.16 and HP ZBook 17/15 G3 Mobile Workstation System BIOS 01.14 has the following enhancements added:
  • Added a command to calibrate the internal DreamColor display brightness.
  • Added S4/S5 WOL support for the HP Docking Station.
  • Removed the USB Preboot option from F10 (BIOS) setup menu.
  • Fixed an issue where boot device could not be found after disabling the USB port in the F10 (BIOS) setup menu.
  • Fixed an issue where the HP Docking Station would not work after a BIOS update.
  • Added the new DGPU VBIOS to support new graphics memory suppliers.
  • Added HP Docking Station PXE boot support.
  • Added HP Elite USB-C Dock support.
  • Fixed an issue where the Micron M600 M.2 SED SSD could not be detected after multiple shutdowns.
  • Added UEFI PXE boot to support the ACE USB-C Dock.
HP EliteBook Folio G1 System BIOS 01.12 has the following enhancements added:
  • Fixed issue where system could not resume from S3 in Windows 7 when Modern Standby was enabled in the F10 (BIOS) setup menu.
  • Fixed an issue that caused the computer to draw more power than expected when it was powered off (S5 state).
  • Fixed an issue where the C9/C10 option would show as disabled when switching to Modern Standby.
  • Fixed an issue where the SCCM USB and NIC connections would intermittently drop when connected to a USB-C Ace Dock.
  • Fixed an issue where the computer would black screen with a white drop-down box (where the user would normally enter the BitLocker PIN) when the computer enabled BitLocker and connected to an HP Docking Station.
  • Fixed an issue where the computer would hang during the Battery Calibration test.
  • Fixed an issue where the boot device could not be found after disabling USB ports in the F10 (BIOS) setup menu.
  • Fixed an issue where the computer would hang after saving custom default settings in the F10 (BIOS) setup menu.
  • Added support for the new Hynix 16Gb/32Gb memory modules.
  • Fixed an issue where the network adapter on a USB-C Dock would not show in the boot menu.
  • Added support for the HP Elite USB-C Dock.
  • Fixed an issue where BSOD 0x9F would occur while running a video stress test in Windows 7.
HP Elite x2 1012 G1 System BIOS 01.20 has the following enhancements added:
  • Fixed an issue where the computer was not able to read/write to the SanDisk 200GB Ultra Micro SDXC card.
  • Added support for the new Samsung 16Gb memory module.
  • Fixed an issue where the network adapter of the USB-C Dock would not show in the boot menu.
  • Fixed an issue where the keyboard firmware update would fail when attempting an upgrade to the travel keyboard firmware when powering on for the first time.
HP EliteBook 1030 G1 System BIOS 01.16 has the following enhancements added:
  • Fixed an issue where the incorrect memory size displayed in a Windows computer and in the HP UEFI Diagnostics tool.
  • Fixed an issue in the VBIOS where the computer would hang during installation of a 16-bit application.
  • Updated the VBIOS version in F10 (BIOS) setup menu.
HP EliteBook Folio 1040 G3 System BIOS 01.10 has the following enhancements added:
HP ProBook 650/640 G2 System BIOS 01.07 has the following enhancements added:
HP ProBook 470/450/440/430 G3 System BIOS 01.16 has the following enhancements added:
HP ProBook 11 EE G2 System BIOS 01.05 has the following enhancements added:
HP EliteBook 745/755 G3 System BIOS 01.18 has the following enhancements added:
  • Made improvements to the boot time for Windows 10.
HP ProBook 645/655 G2 System BIOS 01.08 has the following enhancements added:
  • Fixed an issue to remove the "beep" sound in the F10 (BIOS) setup menu after restarting from the operating system.
  • Fixed the Embedded Controller Recovery post screen pop up while booting intermittently.
HP ProBook 455 G3 System BIOS 01.15 has the following enhancements added:
COMPONENT VERSION
  • HP EliteBook 850/840/820 G3, ZBook 15u G3 Mobile Workstation: System BIOS 01.14
  • HP ZBook 17/15 G3 Mobile Workstation: System BIOS 01.14
  • HP ZBook Studio G3 Mobile Workstation: System BIOS 01.16
  • HP EliteBook Folio G1: System BIOS 01.12
  • HP Elite x2 1012 G1: System BIOS 01.20
  • HP EliteBook 1030 G1: System BIOS 01.16
  • HP EliteBook Folio 1040 G3: System BIOS 01.10
  • HP ProBook 650/640 G2: System BIOS 01.07
  • HP ProBook 470/450/440/430 G3: System BIOS 01.16
  • HP ProBook 11 EE G2: System BIOS 01.05
  • HP EliteBook 745/755 G3: System BIOS 01.18
  • HP ProBook 645/655 G2: System BIOS 01.08
  • HP ProBook 455 G3: System BIOS 01.15
REASON FOR CHANGE
Regular quarterly release.
IMPACT OF CHANGE
None.
Components affected:
HP EliteBook 850/840/820 G3, HP ZBook 15u G3 Mobile Workstation, HP ZBook 17/15 G3 Mobile Workstation, HP ZBook Studio G3 Mobile Workstation, HP EliteBook Folio G1, HP Elite x2 1012 G1, HP EliteBook 1030 G1, HP EliteBook 1040 G3 Notebook PC, HP ProBook 650/640 G2 Notebook PC, HP ProBook 470/450/440/430 G3 Notebook PC, HP ProBook 11 EE G2 Notebook PC, HP EliteBook 745/755 G3 Notebook PC, HP ProBook 645/655 G2 Notebook PC, HP ProBook 455 G3 Notebook PC
DATE OF CHANGE
Effective date : 28-Apr-2017
Hardware platforms affected : HP Elite x2 1012 G1, HP EliteBook 1030 G1 Notebook PC, HP EliteBook 1040 G3 Notebook PC, HP EliteBook 745 G3 Notebook PC, HP EliteBook 755 G3 Notebook PC, HP EliteBook 820 G3 Notebook PC, HP EliteBook 840 G3 Notebook PC, HP EliteBook 850 G3 Notebook PC, HP EliteBook Folio G1 Notebook PC, HP ProBook 11 EE G2 Notebook PC, HP ProBook 430 G3 Notebook PC, HP ProBook 440 G3 Notebook PC, HP ProBook 450 G3 Notebook PC, HP ProBook 455 G3 Notebook PC, HP ProBook 470 G3 Notebook PC, HP ProBook 640 G2 Notebook PC, HP ProBook 645 G2 Notebook PC, HP ProBook 650 G2 Notebook PC, HP ProBook 655 G2 Notebook PC, HP ZBook 15 G3 Mobile Workstation, HP ZBook 15u G3 Mobile Workstation, HP ZBook 17 G3 Mobile Workstation, HP ZBook Studio G3 Mobile Workstation
