HP x360 - 11-ab031tu Product Specifications
1HP28PA
Intel® Celeron® N3060 (1.6 GHz, up to 2.48 GHz using burst technology, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
Intel® HD Graphics 400
500 GB 5400 rpm SATA
11.6" diagonal HD SVA anti-glare WLED-backlit touch screen (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
2 USB 2.0; 1 HDMI; 1 headphone/microphone combo; 1 USB 3.1 Gen 1 (Data transfer only)
30.6 x 20.8 x 1.98 cm
1.45 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP Webcam with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox
Buy Office
