HP ProOne 440/490 G3 23.8-inch Non-Touch All-in-One PC - Specifications
Operating systems
Specification
Pre-installed (Windows)
Windows 10 Pro 641
Windows 10 Home 641
Windows 10 Home Single Language 641
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)2
Pre-installed (other)
FreeDOS 2.0
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
2This system is preinstalled with Windows 7 Pro software and also comes with a license and media for Windows 10 Pro software. Only one version of the Windows software can be used at a time. Switching between versions requires you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of data.
Processors
Specification
Intel Core i7-7700T processor
35 W
Up to 3.8 GHz maximum Turbo Frequency (2.9 GHz base frequency)
8 MB cache, 4 cores, 8 threads
Intel HD Graphics 630
DDR4 memory up to 2400 MT/s data rate
Intel Core i7-6700T processor
35 W
Up to 3.6 GHz maximum Turbo Frequency (2.8 GHz base frequency)
Intel HD Graphics 530
DDR4 memory up to 2133 MT/s data rate
Intel Core i5-7500T processor
35 W
Up to 3.3 GHz maximum Turbo Frequency (2.7 GHz base frequency)
6 MB cache, 4 cores, 4 threads
Intel Core i5-7600T processor
35 W
Up to 3.7 GHz maximum Turbo Frequency (2.8 GHz base frequency)
Intel Core i5-6600T processor
35 W
Up to 3.5 GHz maximum Turbo Frequency (2.7 GHz base frequency)
Intel Core i5-6500T processor
35 W
Up to 3.1 GHz maximum Turbo Frequency (2.5 GHz base frequency)
Intel Core i3-7100T processor
35 W
3.4 GHz base frequency
3 MB cache, 2 cores, 4 threads
Intel Core i3-6100T processor
35 W
3.2 GHz base frequency
Intel Pentium G4560T processor
35 W
Intel HD Graphics 610
Intel Pentium G4600T processor
35 W
3.0 GHz base frequency
Intel Pentium G4500T processor
35 W
3 MB cache, 2 cores, 2 threads
Intel Pentium G4400T processor
35 W
Intel HD Graphics 510
Intel H170
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Graphics
Specification
Integrated
Intel HD Graphics (integrated on processor)
Discrete
NVIDIA GeForce 930MX with 2 GB GDDR5 dedicated memory
Specification
General
23.8 in diagonal widescreen Full High Definition (FHD) display
FHD content is required to view FHD images.
Type
IPS WLED Backlit LCD
Active area (mm)
527.04 x 296.46
Native resolution (H x V)
1920 x 1080
Aspect ratio
16:9
Pixel pitch (H x V) (mm)
0.2745 x 0.2745
Contrast ratio (typical)
1000:1
Brightness (typical)
250 nits (cd/m2) (FHD)
Viewing angle (typical) (H x V)
178º x 178º
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Over 16 million colors
Color gamut (typical)
72%
Anti-glare
Yes
Default color temperature
Warm (6500K)
Actual performance varies.
Memory
Specification
DDR4-2133
Number of slots: (2) DDR4 SODIMM
Configurations
2 GB PC4-2133 SDRAM memory (1 x 2 GB)
4 GB PC4-2133 SDRAM memory (1 x 4 GB)
8 GB PC4-2133 SDRAM memory (1 x 8 GB)
8 GB PC4-2133 SDRAM memory (2 x 4 GB)
16 GB PC4-2133 SDRAM memory (2 x 8 GB)
Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.
Memory modules support data transfer rates up to 2133 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Storage
Specification
SATA drives
500 GB, 7.2 K rpm, 8.89 cm (3.5 in)
1 TB, 7.2 K rpm, 8.89 cm (3.5 in)
SATA and Solid State Drives (SSD)
1 TB, 7.2 K rpm, 8.89 cm (3.5 in) SATA drive
128 GB M.2 PCIe SSD Card
Solid State Hybrid Drives (SSHD)
1 TB, 5.4 K rpm 6.35 cm (2.5 in), 8 GB Hybrid
Removable storage
3-in-1 memory card reader
Supports Secure Digital (SD, SDHC, and SDXC)
Card sold separately.
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
Networking/communications
Specification
Networking
Wi-Fi and Bluetooth
Wireless LAN 802.11a/b/g/n/ac (1x1) and Bluetooth 4.0 M.2 combo
Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Bluetooth function is disabled via BIOS and cannot be enabled by user.
Audio/multimedia
Specification
Type
Bang & Olufsen Audio
2 x 2 W/Channel speakers
(1) Combo Microphone/Headphone jack
High definition audio
Type
Integrated
HD Audio codec
Realtek ALC3252 codec
Audio I/O ports
(1) Combo jack
Analog audio
Headphone/microphone
Internal speaker
Yes – 2 W/4 Ohm
DAC sampling rates
44.1 kHz/48 kHz/96 kHz/192 kHz
ADC sampling rates
Integrated webcam and microphone
HP TrueVision HD 1 MP camera
Dual array digital microphones
Keyboards/mouse
Specification
Combos
HP USB Wired keyboard with volume control and USB wired optical mouse
HP Wireless keyboard with volume control and optical mouse
Ports/slots
Specification
Ports
Rear ports
(2) USB 2.0
(1) USB 3.0
(1) HDMI out
(1) RJ-45 Ethernet port 10/100/1000 GbE LAN
(1) Power connector
Bottom ports
(1) Combo Microphone/headphone jack
(1) USB 3.0 (charging)
(1) USB 3.0 Type C (Fast charging)
Slot
(1) HP 3-in-1 Media card reader
Card sold seperately.
Specification
Windows 10 Software
Productivity
Internet Explorer Homepage (MSN or Bing)
DropBox1
HP Orbit
Amazon (App & URL)
Utilities
HP ePrint Driver2
B&O Audio
HP Documentation
HP Audio Switch
HP System Event Utility
Imaging, Photography, Video, & Film
CyberLink PowerMedia Player3
CyberLink PowerDirector3
Netflix4
Security
HP Recovery Manager
McAfee Checkbox
McAfee LiveSafe (30-day subscription)5
Windows Hello (Windows 10 only)
Support
HP JumpStart
HP Support Assistant
Windows Passport
HP Documentation
HP Audio Switch
HP TouchPoint Manager 6
HP SSRM
HP Sure Connect
Others
ENERGY STAR Certified
Software preinstalled on the system depends upon the configuration selected during the ordering process, and might not be available in every country/region.
125 GB of storage for 12 months. Subscription required thereafter or for additional storage capacity.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds vary.
3On 32/64 GB systems (including Stream), PowerMedia Player and PowerDirector are excluded and a special lite version of Wild Tangent is used. CyberLink PowerMedia Player is only available if product ships with Optical Disc Drive (ODD).
4Availability varies by countries/regions.
530-day trial subscription. Internet access required to receive updates. First update included. Subscription required for updates thereafter.
6HP Touchpoint Manager requires purchase of a subscription and supports Android, iOS and Windows 7 (SP1) or Windows 8.1 or higher operating systems and PCs, notebooks, tablets and smartphones from various manufacturers. Availability varies by countries/regions.
Security
Specification
Software security (standard)
Trusted Platform Module (TPM) 2.0
Hardware security
Lock slot supports HP UltraSlim Cable Lock
Lock sold separately or purchased as an optional feature.
Power supply
Specification
Power supply
120 W external AC power adapter
19.5 V/6.15 A, 88% efficiency
150 W external AC power adapter
19.5 V/7.69 A, 89% efficiency
Physical specifications
Specification
8.45 kg (18.63 lbs)
Dimensions (L x W x D)
580 x 191 x 447 mm (22.83 x 7.52 x 17.60 in)
Weight and system dimensions might fluctuate due to configuration and manufacturing variances.
