1DE86PA
OMEN by HP 15-ax215tx Laptop PC
Intel® Core™ i5-7300HQ (2.5 GHz, up to 3.5 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS UWVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 2 USB 3.1 Gen 1 (Data transfer only)
38.2 x 25.3 x 2.45 cm
2.2 kg
150 W AC power adapter
4-cell, 63.3 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
OMEN by HP 15-ax215tx Laptop PC Product Specifications
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
