HP LaserJet Enterprise 700 color MFP M775 - Tray 2
Tray capacity and paper orientation
To prevent jams, do not overfill trays. Be sure the top of the stack is below the tray-full indicator. For short/narrow and heavy/glossy paper, load paper to less than half of the tray-full indicators.
Tray 2 capacity
Paper type
Quantity
Paper
Range:
60 g/m2 bond to 220 g/m2 bond
Maximum stack height: 25 mm
Equivalent to 250 sheets of 75 g/m2 bond
Transparencies
Minimum: 0.102 mm thick
Glossy paper
Range:
105 g/m2 bond to 220 g/m2 bond
1Tray 2 can print on bond paper heavier than 220 g/m2 in some circumstances, but HP does not guarantee results.
Tray 2 paper orientation
Paper type
Image orientation
Duplex mode
How to load paper
Preprinted or letterhead
Portrait
1-sided printing
Face up
Top edge at the back of the tray
Automatic 2-sided printing
Face down
Landscape
1-sided printing
Face up
Bottom edge toward the right side of the tray
Face down
Prepunched
Portrait
1-sided printing
Automatic 2–sided printing
Holes toward the right side of the tray
Load Tray 2
  1. Open the tray.
    Do not open the tray while it is in use.
  2. Adjust the paper-length and paper-width guides by squeezing the adjustment latches and sliding the guides to the size of the paper being used.
  3. Load paper into the tray. Check the paper to verify the guides lightly touch the stack, but do not bend it.
    To prevent jams, do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
  4. Close the tray.
  5. The control panel shows the tray’s paper type and size. If the configuration is not correct, follow the instructions on the control panel to change the size or type.
  6. For custom-size paper, you need to specify the X and Y dimensions for the paper when the prompt displays on the printer control panel.
Automatic paper sensing (auto-sense mode)
The automatic paper type sensor functions when a tray is configured to the Any Type or plain type setting.
After it has picked up paper from the tray, the printer can detect overhead transparencies, paper weight, and gloss level.
For more control, select a specific paper type for the job or configure the tray for a specific paper type.
Auto-sense settings
To configure the auto-sense settings, follow the steps below.
The steps vary according to the control panel.
FutureSmart 3
FutureSmart 4
FutureSmart 3
  1. From the Home screen on the printer control panel, scroll to and touch the Administration button.
  2. Open the following menus:
    • General Settings
    • Print Quality
    • Auto Sense Behavior
  3. Select one of the auto-sense modes.
    Expanded sensing
    This is the default setting for all trays.
    For the first few sheets of paper that it picks up from the tray, the printer detects light paper, plain paper, heavy paper, glossy paper, tough paper, and transparencies. The printer assumes the rest of the pages are of the same type.
    Transparency only
    The printer distinguishes between transparencies and non-transparencies. This setting provides the fastest printing, but for some paper types it might reduce print quality.
FutureSmart 4
  1. From the Home screen on the printer control panel, select the Settings menu.
    • Copy/Print
    • Print Quality
    Sense every page
    For every sheet of paper that it picks up from the tray, the printer detects light paper, plain paper, heavy paper, glossy paper, tough paper, and transparencies.
    Sense first page
    For the first sheet of paper that it picks up from the tray, the printer detects light paper, plain paper, heavy paper, glossy paper, tough paper, and transparencies. The printer assumes the rest of the pages are of the same type.
    Sense transparency only
Country: Flag Bulgaria
