    Apache Log4j Update
HP Pavilion - 17-ab232ng Product Specifications
1JM16EA
Intel® Core™ i5-7300HQ (2.5 GHz, up to 3.5 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
8 GB DDR4-2400 SDRAM (2 x 4 GB)
Video graphics
NVIDIA® GeForce® GTX 1050 (4 GB GDDR5 dedicated)
  • 1 TB 7200 rpm SATA
  • 128 GB M.2 SSD
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS UWVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1 Gen 1, 1 RJ-45
41.6 x 27.9 x 2.99 cm
2.85 kg
150 W AC power adapter
6-cell, 62 Wh Li-ion
Battery type note
User-replaceable battery
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Lounge
Pre-installed software
CyberLink PowerDirector; Netflix
