HP Pavilion x360 15-bk002tx Product Specifications
Z1D85PA
Intel® Core™ i7-6500U (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
NVIDIA GeForce 930M (2 GB DDR3L dedicated)
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS UWVA WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
1 USB 2.0; 1 RJ-45; 1 HDMI; 1 headphone/microphone combo; 2 USB 3.1 Gen 1
38.2 x 25 x 2.39 cm
2.3 kg
45 W AC power adapter
3-cell, 48 Wh Li-ion
HP TrueVision HD Camera with dual array digital microphone
B&O PLAY; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
Buy Office
