    Fix HP Printer issue on macOS
HP ProDisplay P223 21.5-inch Monitor Specifications
Product image
Figure : HP ProDisplay P223 21.5-inch Monitor
Product features
Specification
Model
X7R61AA
Z4L11AA (Monitor head only)
Type
21.5-inch VA with LED backlight
54.61 cm (21.5-inch) widescreen
Active area (W x H)
47.6 x 26.7 cm (18.74 × 10.51 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal
Up to 178° vertical
Brightness
250 cd/m2
Dynamic contrast ratio (typical)
3000:1 static
5,000,000:1 dynamic (DCR)
Response time (typical)
5 ms typical (gray to gray)
Pixel pitch
0.248 mm (0.039 in)
Pixel pitch inch (PPI)
260.1 cm (102.4 in)
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72%
Panel
Specification
Model
X7R61AA
Type
Active area (W x H)
Resolution
Aspect ratio
16:9
Viewing angle
Up to 178° vertical
Brightness
250 cd/m2
3000:1 static
Pixel pitch
0.248 mm (0.039 in)
260.1 cm (102.4 in)
Color support
72%
User controls
Specification
Buttons or switches
Menu, Minus ("-"), Plus ("+"), Input control, OK, Auto, Power
Languages
10 (Chinese (simplified), Chinese (traditional), Dutch, English, Spanish, German, French, Italian, Portuguese, Japanese)
On-screen display (OSD) user controls
Brightness, Contrast, Color control, Input control, Image control, Power control, OSD control, Management, Language, Information, Exit
User programmable modes
Yes, 10
Signal interface/performance
Specification
Horizontal frequency
24 - 80 kHz
Vertical frequency
50 - 60 Hz
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input/output connectors
(1) DisplayPort 1.2
(1) VGA
HDCP support on DisplayPort
USB
N/A
Video cables included
(1) DisplayPort 1.8 m (5.9 ft)
(1) VGA 1.8 m (5.9 ft)
Audio
N/A
Power
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
28 W
Typical power
20 W
Sleep power
0.5 W
Power cable length
1.9 m (6.2 ft)
Ergonomic features
Specification
Detachable stand (not available on head only model)
Yes
Height adjustment
N/A
Tilt range
-5° to +22° vertical
Swivel
N/A
Pivot
N/A
What's in the box?
Specification
Monitor and accessories
AC power cord 1.9 m (6.2 ft)
DisplayPort cable 1.8 m (5.9 ft)
VGA cable 1.8 m (5.9 ft)
Documentation
CD (includes user guide, warranty, drivers)
HP Display Assistant
Miscellaneous
Specification
User guide languages
Arabic, English, Chinese (simplified), Chinese (traditional), Czech, Danish, Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Brazilian Portuguese, Russian, Slovenian, Spanish, Swedish and Turkish.
Warranty languages
Arabic, English, Chinese (simplified), Chinese (traditional), Czech, Danish, Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Portuguese (Brazilian), Russian, Slovenian, Spanish, Swedish and Turkish.
Color
Black
VESA mounting
100 mm VESA mount
Security lock-read
Yes
Country of origin
China
Certification and compliance
TCO Certified, CEL Grade 2, Microsoft WHQL Certification (Windows 10, Windows 8.1, Windows 7), ENERGY STAR Qualified, EPEAT Gold2, CE, CB , KC, KCC, NOM, PSB, ICE, TUV-S, CCC, CECP, SEPA, EPA, ISC, VCCI, FCC, Taiwan: BMSI, SmartWay Transportation Partnership for NA Model
Compatibility
Compatible with platforms using the VESA standard video modes. Recommended for use with HP products.
Service and warranty
Protected by HP, including a 3 year standard limited warranty. Optional HP Care Pack Services are extended service contracts that extend your protection beyond the standard warranties.
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand: 51.5 x 19.12 x 38.9 cm (20.28 x 7.53 x 15.31 in)
Unpacked without stand (head only): 51.5 x 5.49 x 32.7 cm (20.28 x 2.16 x 12.87 in)
Packaged: 58.9 x 14 x 42 cm (23.19 x 5.51 x 16.54 in)
Head only: 2.9 kg (6.4 lb)
Unpacked with stand: 3.5 kg (7.7 lb)
Packaged: 4.7 kg (10.4 lb)
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7° C (101.66° F) max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,404 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes (except cables)
Mercury-free display backlighting
Yes
