Remove and Replace the Audio Board on HP ProBook 640 and 645 G2 Notebooks
This document applies to HP ProBook 640 and 645 G2 notebooks.
HP ProBook 64x G2 notebook
Before you begin
  • Have available a small Phillips-head (P1) screwdriver, a small flat-bladed alignment/pry tool, and tweezers or pliers.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing, replacing, and/or servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risks and refer to the product's warranty before attempting to service the computer.
Video overview
See the video before removing and replacing the audio board.
The video and graphics in this article depict a specific configuration of the notebook. These same removal and replacement procedures apply to all configurations of HP ProBook 640 and 645 G2 Notebooks.
Removing the audio board
Use the steps in this section to remove the audio board.
Step 1
Remove the bottom cover.
The bottom cover
Step 2
Remove the battery.
The battery
Step 3
Remove the optical drive or optical drive dummy.
The optical drive or optical drive dummy
Step 4
Remove the disk drive...
The disk drive
... or the solid state drive.
The solid state drive
Step 5
Remove the wireless WAN module.
The wireless WAN module
Step 6
Remove the wireless LAN module.
The wireless LAN module
Step 7
Remove the top cover.
The top cover
Step 8
Remove the system board.
The system board
Step 9
Find the two 3 mm P1 Phillips-head screws that secure the audio board to the base enclosure...
Ensure that the display panel assembly is properly braced to prevent it from falling backwards and damaging the display panel assembly.
The two 3 mm P1 Phillips-head screws
...and remove them.
Removing the screws
Step 10
Carefully remove the audio board from the retention tab, alignment pin, and cut out on the base enclosure.
Step 11
Place the audio board into a static dissipative bag.
Placing the audio board in a static dissipative bag
Replacing the audio board
Use the steps in this section to replace the audio board.
Step 1
Remove the audio board from the static dissipative bag.
Removing the audio board from the bag
Step 2
Carefully insert the audio board into the cut out in the base enclosure and place the audio board onto the alignment pin and under the retention tab on the base enclosure.
Inserting the audio board into the base enclosure
Step 3
Replace the two 3 mm P1 Phillips-head screws that secure the audio board to the base enclosure.
Replacing the screws
Step 4
Replace the system board.
The system board
Step 5
Replace the top cover.
The top cover
Step 6
Replace the wireless LAN module.
Step 7
Replace the wireless WAN module.
Step 8
Depending on your particular notebook, replace either the solid state drive...
... or the hard disk drive.
The disk drive
Step 9
Replace the optical drive or optical drive dummy.
The optical drive and an optical drive dummy
Step 10
Replace the battery.
The battery
Step 11
Replace the bottom cover.
The bottom cover
Country: Flag Bulgaria
