Z4Q49PA
HP Pavilion x360 13-u131tu
Intel® Core™ i3-7100U (2.4 GHz, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
Intel® HD Graphics 620
1 TB 5400 rpm SATA
33.8 cm (13.3) diagonal FHD IPS UWVA WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1
32.64 x 22.2 x 1.98 cm
Starting at 1.66 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion x360 13-u131tu Product Specifications
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
Office 2016
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
