    Apache Log4j Update
HP LaserJet Enterprise 700 color MFP M775 - 13.B2.A1, 13.B2.D1 jam error tray 1
Use the following procedure to check for paper in all possible jam locations related to tray 1. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.B2.A1
  • 13.B2.D1
  1. If jammed paper is visible in Tray 1, clear the jam by gently pulling the paper straight out.
    Figure : Remove jammed paper from Tray 1
  2. If you cannot remove the paper, or if no jammed paper is visible in Tray 1, close Tray 1 and open the right door.
    Figure : Open the right door
  3. Gently pull the paper out of the pickup area inside the right door.
    Figure : Remove jammed paper from the pickup area
  4. Close the right door.
    Figure : Close the right door
